We value your privacy.
I have noticed lately when cutting 1.5" thick stock (pine) that my table saw (contractor saw) will all of a sudden shut down. If I wait a few minutes, push the reset button on the motor, and start it back up, it will run for a few more minutes and then stop. I am pushing the wood through slowly, and I do not notice this on thinner wood. It will do it with the rip blade or the combo blade in place.
>I'm certain that others will have better trouble shooting ideas, but to me it sounds like the motor is overheating. Therefore, I would check the sharpness/dullness of your blade. Hopefully, it will be that simple.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
Guest
Re: Tablesaw Motor Question
>You don't give much to really go on. How about posting motor amp size? Extension cords used? Blade size etc.
If you are using too small a wire in the cord, you may not be getting all of the amps through that the motor can use.
When I am out on a job-site with my contractor saw, and have lots of thick ripping that I want to really push through, I drop down to a 7.25" blade. This will increase the torque, and may reduce the kerf width.
>It is the thermal protection operating. If your blade is sharp and you are not pushing the stock through too fast, it is likely that the overload protection switch needs to be replaced, This happened to me with my Jet tablesaw. Jet sent a new one for free. It is simple to replace if this is the problem.
>Greg is spot on , for whatever reson your motor is heating a bit to much , the Thermal overload kicks out and shuts down and won't let the motor start up again , until the temp has dropped.
Hard to say about touchy switches, I have a Delta Drum sander that I have always thought that either the feed motor thermal switch was touchy or the feed motor was grossly underpowered.
Check the motor plate and see if your circuit and cord are big enough. If not, upgrade the circuit and cord.
If the motor is not sealed, blow it out.
Try a thin kerf sharp blade.
If the switch is touchy, replace it. There should be temperature rating on the motor. Mine does not trip until the motor gets hot to the touch. Something like 140 degrees. Too hot to hold your hand on.
Is this a new problem? Did this saw and this blade not do this in the past? What changed? Blade dull? Pitch on the blade? Thicker tougher wood? Added in a new longer thinner cord? Dirt build up in the motor? Aging switch becoming touchy? My RAS has become touchy over the years, but I don't use it much, so I just wait for it to cool down.
>Just for kicks throw the multimeter on the switch when it shuts down then move on to the on / off switch. I'll admit to by-passing the the overload switch before but only to isolate and troubleshoot.
The motor does not get hot to the touch, I tested that when it tripped yesterday. Also, for the rest of the day yesterday I pushed things REALLY slow and nothing happened again. The saw is over 6 years old, and the blades are clean, but have never been sharpened. For some reason I have been putting that off.
I will start sending the blades off to get sharpened, and I will look into the sensitive thermal switch issue. I need to do this before the weather gets warm. This is a real pain in the rear when it is 85 degrees outside.
>While reading your post and the responses, I realized I've seen this issue raised here before. It seems the answer at the time turned out to be sawdust that was caked around something inside the motor and a few blasts of compressed air was all it took to remedy the problem.
As long as this is a new occurrence and the saw cut fine normally before, then you can probably dismiss other causes for now and have a closer look at the motor's thermal protection. It really sounds like the motor is overheating and being turned off to protect itself.
>18 amps is a bit much for a 20 amp circuit. If you consider this a "long duration" or continuous load, then the circuit is supposed to be limited to 80% of its rated capacity or 16 amps. This would have more effect if the circuit was also longer than average (distance not time) and could be affected by poorly made connections.
In spite of that, I would suspect that either your blade's getting dull or that the thermal switch has degraded or both.
Blow out the fan on the motor, mine moves lots of air.
>You don't say which Contractor's saw you have for some strange reason, but anyway, some of the older Contractor's saws have the power switch mounted to the cabinet with an electrical box mounted inside the cabinet that in time fills up with dust. Lousey place for an electrical box and switch, so on my saw I removed it and mounted a paddle switch under the fence rail. So you say your running a 18 amp saw on a 20 amp breaker with a 12 gauge extension cord. A 20 amp breaker is probably too small, especially if anything else is running on that circuit, such as, lights ? fan ? radio ? air filtration machine ? etc. and how long is the extension cord ? I would try blowing the motor and switch out, and consider running a dedicated 30 amp circuit, or run a 220V circuit and wire the saw for 220V.
>Most of the time, a saw that is rated for 18 amps will draw considerably less than that when running. The issue would be if it trips when starting. If it did that, then you might be dealing with too small of a breaker. As long as it starts OK and is not tripping the breaker, then 20 amps is fine. I would not spend any money to fix a non-existent problem.
The fact that the motor does not seem hot to the touch and that it is the reset on the motor that is tripping, would indicate either that the thermal overload is bad (appears most likely), or the fan is blocked and letting the motor overheat. (less likely as the motor is not hot to the touch.)
>Dan, not only at startup is the motor useing more amps, but under a load also. Anyway, who knows ? maybe the reset switch is dirty, or on it's last leg. For about 10 years I ran my Contractor's saw on a shared 110V circuit, the lights in the shop would dim briefly when I'd start the saw, or put it under a fairly decent load. I can't remember the reset ever triping, but the breaker in the panel did on rare occassions, I supose because I new how far to push it after a couple times. About 4 years ago I had the shop rewired because I wanted a breaker panel in the detached shop, and I needed 220V for a dust collector I had bought. At that time we decided to run a few more 220V circuits, one for the air compressor, and another for the table saw. I wish I had done it 14 years ago when I had bought the saw. No more lights diming, the saw comes up to power immediately, it takes a load better. I don't think many people think to run a table saw on a dedicated 110V or 220V circuit. It should really be common practice.
>Once again, thanks for the excellent help. Every once in a while, it will trip the breaker. When this happens it is usually cold. I am guessing the belt on the saw develops a memory spot and when trying to start it takes too much current and trips the breaker.
The extension cord is 25 ft long and 12 gauge. I always thought this might be the problem.
I do have 220 available in the shop thanks to the previous owner of this house owning a welder. I would need to run an extension cord, probably no longer than 25 feet. If I decide to do this, what gauge wire should I use in the extension cord?
>True, it draws more under load, but in practice, I doubt that many of us ever load the saw to the max draw. If your lights were dimming, then you probably did have a circuit that was too heavily loaded, but I had a contractors saw for many years that was run on a 20 amp circuit with no problems at all. Running larger wire or 220 volt circuits is never a bad idea for this kind of equipment, but my point is that if the circuit is running the saw OK then I would not spend any money or time to fix something that is not broken. If it is causing obvious problems, then that is a different story.
If you wire a box closer to your saw , using GreenField, Flex , Emt,with THHN stranded wire to a 250V. 20 amp twist lock plug and receptable it will be a better installation then running a extension cord which is subject to damage , shorts and so on.
>Just a thought, have you tuned up your saw lately? Make sure everything is set parallel, Fence to miter slot, blade to miter slot etc Make sure you are using a splitter to prevent the kerf from binding on the back of the blade 6 years is a long time between tune ups for a contractor saw. Sharp blades are a must
>Most of the bigger causes have been covered, but here's a couple more to ponder:
1) Have you felt the plugs on the end of the saw's cord, and also your extension cord? Constant flexing of cords often causes some of the strands of wire to break down at a plug, therefor reducing the current carrying ability of the cord assembly. Any heat felt here is a flag that resistance is occuring.
2) Most houses are wired with the cheaper 110v duplex outlets. These are only rated for 15 amps, though often found on circuts fused at 20 amps. Is the outlet itself getting warm, especially with an 18 amp motor? Any outlet between the one you are using and the breaker box could have a weak connection.
3) Do you us an extension cord for your saw frequently? If so, go buy an adequately long enough cord & good plug, and rewire your saw with a long enough cord to plug directly into the wall and eliminate the extension cord.
>Others have pretty much covered the potential issues for your motor except for checking to see is the motor has oil caps on the bearings. Some saw motors have small plastic plugs on the ends that lead to the bearings. The insturctions would tell you to lubricate the bearings periodically with a couple of drops of oil. Remove the belt and try turning the motor and the saw arbor by hand. They should both spin easily. If they do not, look there for your source of trouble.
Dull blades coupled with a sawdust clogged motor or motor fan can cause the problems you described. The temperature of the motor overheating takes a while on a TEFC motor to reach the point where the outside case gets hot. After cutting a piece, let the motor run for a minute before turning off the saw so the fan has a chance to cool off the motor before shutting it off.
