We value your privacy.
>Like many others, I have long wanted to make my woodworking bench mobile. So I made this simple and inexpensive wooden cam-actuated retractable caster arrangement. The hinges are standard gate hardware and allow the wheels to be readily removed. The pivot is a 5/8" carriage bolt mounted from the back side of a solid maple block that is screwed to the front trestle leg. The handle levers are simple black pipe and store out of the way when not in use. Although they look a little ugly, they work great and allow this 350 lb work bench to be easily moved anywhere I need it.
I'm in the process of designing and building a workbench. One of my plans is to take the wheels off of the Rockler Mobile Base and bolt them to the legs. I was in last weekend looking at the base, and the wheels could just as easily be bolted to my legs as affixed to the base.
Thoughts?
BTW - I've got the bench top, bought it from someone who salvaged the wood from a bowling alley. I've got about 8' x 3.5' worth of hard rock maple, a little over 2" thick, and laminated together. Even have the mahogony dots inlayed.
>Thanks for the detailed shots. This solves one of the problems I need to confront, how to lower and raise the leg that's in the back corner of where I put it away.
