Cabinets and vanities - Need a backing?
Terry Alexander
>For those following my threads, I have decided to build my own vanities and cabinets. We did texture and finish the walls everywhere.....I.E. where all vanities and cabinets will be located.
Q: Is there any compelling reason to put a backing on the cabinets and vanities?
As always...TIA
Terry Alexander in West Texas
Re: Cabinets and vanities - Need a backing?
Robert R. Clough - Thorncraft
>I assume you mean the bathroom vanity (sink) - I'd say no need there. Ours has no backing and my new one (when I get around to building it) shan't have one either. As to kitchen, I'd say a backing as it makes it easier to hang. Most everything I've read here shows cabinet backs.
Yes
David Yoho
>The most compelling reason to install a back on cabinets is strength. It will "lock" everything together.
David
Re: Cabinets and vanities - Watch for mildew
Bricofleur
>The backing gives lot of strengh to the cabinet, for sure. The issue with sink cabinets and vanities is mildew. You must be sure no water or humidity can't get caught between the backing and the wall.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
For the investment ...
Ellis Walentine, Host
>... I believe that backs are a good thing. First, as noted, they square up the cabinet and give it structural strength, which may not be much of an issue after everything is installed, but it is a welcome feature until then. Secondly, the back completes the enclosure and helps keep mice and other vermin out. (Forgive me if you don't have any such pests.) Other benefits as I sees 'em: If you have to install the cabinet(s) with any space between the cabinet and the wall, you don't need to worry about stuff falling down into the crack and never being seen again; and they present a finished appearance to the insides of the carcases. If the backs happen to be melamine-coated or lacquered, they also resist staining from your cabinet contents. Last but not least, they aren't difficult or expensive to add to the job. Any additional weight or cost is more than offset by the advantages.
My 2¢,
Fred Davis
>Yes,
most of which have been noted by the other posts.
On occasion when the plumbing is relocated ( like for a double sink vanity for instance) backs in addition to the other reasons will cover the damage to the drywall.
Well heck the pipes are in the way to install cabinet with back you think.
So , cut off the water supply to the pressure lines , unscrew the angle stops or cut them off if sweated and install the cabinet then redo the angle stops.
Also use eschutcheons on the pipe to cover the hole around the pipes.
In the area under the Kitchen and Vanity sinks, cover the cabinet floor with some linoleum you may have left over from floor covering.
Lasts a lot longer then the film finish you probably put on the wood.
FredD
Re: Cabinets and vanities - Need a backing? A no v
Justin Szeliga
>Well now, as far as the structural soundness goes, you could put a 2"-3" rail on the upper back of the cabinets to keep them from racking. A glued back will make the cabinets much stronger, but if you want the backs open a top rail & screwing the sides to the wall with pocket screws & anchors will stiffen things up plenty. Actually, if you were to french cleat the cabinet or cabinets to the wall the wall cleat could be used to screw the cabinet sides to. There are ways of having the necessary rigidity without a back, just a glued in back is very strong & very cheap/easy.
Peace
Justin
Jim Dillon
>Terry,
One of my first "real" projects was a bathroom vanity. I put a back on it because, well..., that is what the plan called for ;-). For probably 4 years, we had no AC and live in the MD/VA area so things get pretty darn humid in the bath/shower during the summer. I never noticed a problem with mildew inside the cabinet, but did have a problem with the drawers that I had to sand down a bit because they expanded. The doors on the cabinet were probably opened a few times each day during normal use.
On my kitchen sink cabinet I also used a back and only had a mildew problem when the P-trap worked loose and dripped over time. By the time I discovered it, there was mildew on the floor (and water). Once that was fixed, everything has been fine. I did fashion a wooden cover for the undersink garbage bin to keep the moisture level down (and mice out). All in all, for the many reasons stated, I vote for a back.
Jim
All good points-Thanks to all - Backing it will be
Terry Alexander
Re: All good points-Thanks to all - Backing it wil
mdclor
>Terry,
I don't know the economics of the situation, but you might consider using pre-finished maple ply for the cabinet insides. It will save you a lot of finishing time and probably give a better, harder finish than you would be able to apply yourself. A friend of mine that makes his living as a cabinetmaker has gone to this method and has been very happy with the results.
HTH,
Merle
