tapering a blind hole for a leg tenon
Bill Tindall, E.TN
>To review.....I took a class that involved making a short three legged stool. I thought the design was flawed because the leg tenons were not tapered. To try to fix this deficiency I did not fit the tenons in class and then asked the sages of WC how to taper a blind hole such that I could then taper the tenons and wind up with a leg that would tighten with use. Among the more practical suggestions was one to make a taper cutter. I am not sure I executed this suggestion correctly but what I wound up with worked.
I cut a tapered plug with a stem for turning it. A slot was cut in the taper with a dovetail saw and a section of fine toothed hacksaw blade was inserted. The problem to be solved was how to turn it. There was too much resistance where it crossed the end grain to turn it by hand. Various hand powered attempts at turning resulted in the cutter binding, again at the end grain, and splitting the devise as show in the PIC. Fortunately these tapered plugs were easy to fabricate on the lathe. The fourth and final attempt was made using dense maple, with a short stem and very small blade projection, all key elements. It turned out that turning it fast with a power drill was the secret to success. It took but seconds to achieve the taper. I tried smoothing the taper with sandpaper wound around the plug and this operation smoothed the taper.
The picture shows the bottom of the stool with two legs dry fitted as well as a broken plug, the successful plug with the hacksaw blade (red) inserted and the sanding plug.
Thanks to who it was that suggested making this cutter.
Re: tapering a blind hole for a leg tenon
Re: tapering a blind hole for a leg tenon *LINK*
Fred Davis
>No taper needed, this is one of 12 I made for Christmas gifts twenty years ago out of Red Oak.
Legs are 1 3/4" Oak handrail and the top is 2" Red Oak from two planks that made them all.
Aside from normal wear and tear , joints remain as tight as the day they were made, the legs also have a Oak pin inserted from the side of the top that captures the leg and is capped with a Oak cap.
FredD
http://picasaweb.google.com/lh/photo/egcCUzurVq98JVRrOjF5tQ?authkey=Gv1sRgCOGs5-W73Nv9Xw&feat=directlink
