warped table top
warped table top
warped table top
dan long
>HI I have been making a 7' round table and 2 times it has warped I am using white oak. This has not happened before. I have cut all the boards down to no more than 3" and glued them up with each having the grain going in opposite directions. I am wondering if I re glued a second layer underneath either in opposite direction or parallel would this prevent it from warping again.
Thanks Dan
Re: warped table top
need more data
Bill Tindall, E.TN
>The things you did to presumably minimize warping are unnecessary and they lead to an appearance that is less than best. Top can be glued up to achieve best appearance using what ever width lumber you have available. I have tops with 18" wide pieces in them.
What exactly is the problem? Is the whole top cupped or wash boarded, twisted, what and how much???
Is the problem you speak of normal warping of a large top? if so don't fret over it. The frame to which it is attached will pull and keep it flat.
However, if the warping is excessive it could be a result of where/how you stored the top after assembly or it may indicate wet wood.
Re: need more data
dan long
>HI i haven't glued it all together yet but the two pieces that are ready to be attached ar 7'x 3.5 wide. both of them have cupped about 1/4'' on the ends.THis happened once before on the same pieces so I cut them again and re gluded them flat and they still cupped not twisted or anything like that. So you think that the bracing that will go underneath will keep it flat.
Thanks Dan
Re: need more data
chuckbeck in cent il
>If your top is glued up and you have not attached it to a base of some sort, then how are you storing it. Any panel stored with circulation on one side and not the other will cause the panel to warp towards the dry side.
chuckbeck
Dick Coers
>I suspect you are dealing with a moisture problem. White oak is very difficult to dry. I can't remember how thick you said the top was, but as it gets thicker, it get way tougher to dry. Quarter-sawn makes it even worse. How long have you owned the wood? If it's fairly new to you, it may have not been kilned correctly. I once bought some quarter-sawn white oak to resaw and make a arts & crafts style room screen. Those pieces became skis very quickly when I revealed the wet core of the stock while resawing. If it's new to you, take it back and have them stick it with a moisture meter.
Definitely don't glue up just one layer under it. Plywood always has odd numbers of plys to balance the construction. Two thick plys is a disaster waiting to happen. Split glue joints, etc....
Something is too wet
Bill Tindall, E.TN
>First let us dismiss the species issue. Whilte oak is not more prone to doing these sorts of things than anything else. Yes, it requires more care drying than pine but kiln operators know how to reliably dry white oak to furniture making standards.
Cupping 1/4" on a 3" board is extreme!
What is the source of this lumber? We sold lumber for almost 30 years. Once we tried a new supplier, a small kiln operator (also a new, small kiln operator as it turned out). Lumber seemed good and we delivered some to a customer. I was by the shop a few days later and glanced at the delivered stack which they had yet to use. The top boards had cupped up about 1/2", an alarming sign that the lumber was wet. I gathered it up and returned with lumber from a reliable supplier. The wet lumber measured 16% MC, far above something that could be worked for cabinetry. To my knowledge we never got under dried lumber from a large kiln operation. If you dried this lumber yourself, then it clearly isn't.
The only way lumber cups standing around is gain or loss of moisture. So, either the lumber was extremely dry and it was moved to a very damp location and only exposed on one side as it regained moisture OR this lumber was very wet by furniture standards and it is loosing moisture from only one side. If you lay a piece on the bench for a few days and the edges curl up then the lumber is wet and unsuitable for the task at hand.
Wet oak gives off a sharp odor when sawed, kinda burns the nose. The saw dust will feel wet, not dry and fluffy.
Steve in Denver
>Rockler has a moisture meter on sale for $25, might be worth picking up and you could hopefully avoid issues related to high moisture content in the future.
http://www.rockler.com/product.cfm?page=21326&filter=moisture
