THE WOODRAT IS BACK!
ageing wood
ageing wood
ageing wood
Jim Hamer
>I have heard that there is a chemical that can be sprayed on wood to age it. I don't remember what it is - could you help.
Re: ageing wood
Re: ageing wood
paul waddle
>Tannic acid will react with oak to turn it brownish grey,that's all I know. I'm sure there are other chemicals that react with other woods and change their color. Not sure if this produces an aged look. pw
Re: ageing wood
Re: ageing wood
John Veerkamp,Western Mo
>Misting with household ammonia will also age some woods. A solution of vinegar and steelwool(iron) will darken many woods. What kind of wood are you trying to age? It will vary from species to species. And whatever species you have , test with scraps before you try your finished project.
Re: ageing wood
Re: ageing wood
Pete in Holland, MI
>Cherry can be instantly aged with Easy-Off oven cleaner. I forget what the active ingreedient is to do that, nor what it'll take to neutralize it.
Pete
Re: ageing wood
Re: ageing wood
Jim Hamer
>I'm trying to age spruce
Re: ageing wood
Re: ageing wood
>Spruce can be aged/silvered by misting on amonia. Do it outside or in a well ventilated space. Mist on a coat and let it dry. You can do several coats to deepen the color. The project may need sanding after treatment.
John
Re: ageing wood
Re: ageing wood
DizD
>There used to be a two part chemical kit marketed under brand name of Old Growth - I haven't seen it in catalogs lately. I used it on white pine with good results. The reason this is fresh in my mind is because I was cleaning out some old files last Tuesday and threw away all of the info sheets I had.
Re: ageing wood
Give it a suntan
Ellis Walentine, Host
>Spruce guitar tops darken with exposure to oxygen and ultraviolet radiation. I've known instrument makers who hang their spruce tops in an intense light box to mellow the color, and presumably affect the grain in other ways that improve the tone. Michael Dresdner, having been the R&D guy for Martin Guitars and the general manager for Tacoma Guitars would know a lot more about this. Maybe he'll stumble on this thread.
Probably the safest and least disruptive way to color spruce would be with a dilute dye, applied either in advance of finishing or as an addition to the finish. In the latter event, it is called a toner.
Cheers,
PS Anytime you use strong acids (HCl, HNO3) or strong bases (Oven cleaner, Sodium hydroxide) to fiddle the color of wood, be sure to neutralize the wood thoroughly afterward by washing it liberally with a mild solution of the opposite compound, e.g., dilute ammonia for acids and dilute vinegar for bases, followed by a clear water rinse. Otherwise, you will leave salts of these compounds in the wood and they can ruin your finishing attempts. Of course, these treatments need to be conducted with extreme caution and rigorous eye and breathing protection (can't recall the vapor mask class required, but check into it) and plenty of ventilation.
