Colonel - about the Osborne miter gauge..
>I've had it about 2 months now. I just gave it a major workout pushing pressure treated 4 x 4 x 8'. I had to cut a lot (12 boards x 3 4" dadoes). It manages to push them right along - though there was some difficulty of course - that's very heavy stuff. It cuts long stuff very well - the ability to extend it helps. The stop on the gauge itself allows you to make a lot of repetitive small cuts. I've only done 45 and 90 with it. It has performed like a champ.
I think it is worth considering.
Re: Colonel - about the Osborne miter gauge..
>Thanks JL,
I appreciuate your providing that info. It seems you have used it to its design parameters successfully, and I'd plan to stay within that envelope. I guess I'll start price comparison. Thanks.
George
I have one of these, not thrilled with it
Dan Mitchell
>Mainly because one of the 3 expansion points that keeps the gauge true in the miter slot is off the table unless the gauge fence is quite close to the blade (i.e., with wider boards). Here's a FWW summary, with which I agree:
"The Osborne gauge has a unique design with a support arm that forms a triangle with the fence and guide bar. The arm adjusted quickly with accurate detents at common angles. However, the gauge allowed too much flex and yielded inaccurate cuts in certain situations.
One end of the fence connects to the center of the guide bar. The opposite end of the fence mounts to the support arm, which, in turn, is attached to the front of the guide bar. The parts pivot at each of these three attachment points.
Markings on the adjustable arm measure the angle, and a ball plunger holds the fence in place. The plunger allowed for a quick return to 90� or any of the preset angles in each direction.
The EB-3�s guide bar has three adjustment points to help provide a snug fit in the miter-gauge slot. The problem with the overall design is that wide stock pushes one of these points out of the miter slot, allowing the guide bar and entire miter gauge to flex.
The EB-3 incorporates an eccentric mounting point at the rear of the bar for the adjustment arm, allowing the user to fine-tune the angle settings. However, even with this mounting point tightened as much as possible, there was play in the mechanism and also at the point where the fence and bar meet, adding to the overall inaccuracy, especially when pushing long or heavy stock.
UPDATED 11/27/2006: The EB-3 Miter Gauge is now being produced by General International.
Editor Test Results
Ease of Use N/A
Quality Fair"
If I had it to do over again, I would probably not get thge Osborne. If you'd like George, I can email you a PDF of the 2003 FWW review of miter gauges from which this quote is taken, let me know.
Dan
Re: I have one of these, not thrilled with it
Rob Stokes in N. Vancouver
>I know a few years ago, after Osbourne was sold that the manufacturing was moved offshore and went downhill. I kicked myself because I think I missed the boat on buying one of these when they were made "on shore".
But I'd also heard that most of those quality issues had been overcome. Has anyone bought one of the recent ones and if so, is there anything to add?
I've got an original Incra 2000, which definitely has it's place in my shop. But there's a lot it doesn't do well, so I'd like to augment it with another decent miter gauge. I'm hoping the Osborne could be it?
Rob
Dan Mitchell
>Mine is marked "General International", whether it was made domestically (US) or elsewhere, I don't know. I see the FWW review which gave the gauge a "fair" rating was from 2003, a later addition to it states Osborne became part of General International in 2006, so the one they tested was presumably made prior to any moving of manufacture.
The execution of mine is fine; it looks & feels well made. I think the design is flawed.
Dan
Re: I have one of these, not thrilled with it *LINK*
>Rob, Dan has made a good assessment of the flaws of the Osborne. The Delta miter gauge has a similar design and might be beefier (see link). If you are by a store you can give it a look see.
I was happy to have been given the Osborne. I don't know if I would have purchased it myself - but it has worked.
Delta
Lee Schierer - McKean, PA
>If you are looking for a miter gauge take a look at the Kreg miter gauge. LOML bought one for me for Christmas and thus far I am very pleased with it. I like the adjustability of the fence from left to right and the fact that I can move the fence when cutting angles to get more support closer to the blade and return the fence to the 90 degree setting and come right back to the accurate set up for the measurement scale mounted on the fence. There are fixed angle stops for commonly used angles that are locked in place via a shot pin. The flip up cut off stop makes repatative and non-repetative cuts easy to do.
The only thing I don't like is that the fence flexes, because it is aluminum, when makeing cuts in longer pieces (over 3-4 feet) that stick out to the left of the fence.
It's about the same price as the Delta heavy duty copy of the Osborne miter gauge.
Lee
Steve in Denver
>I'd give a good look at the Jessem Miter Gauge if you're looking for something that is "beefy."
http://www.jessem.com/mite_r_excel.htm
>Good Afternoon Steve,
I may be cutting off my nose to spite my face, but JessEm is on my "S"
list for their poor customer service when I began using their Mast-R-Lift in my router table. I do not plan on buying a
another of their products even though the Mast-R-Lift satisfactorily performs.
George
>Thanks Lee,
I'll look at Kreg also.
George
Hey Dan
>Good Afternoon Dan,
If you could email me that file I would appreciate it very much. Thanks.
George
It's on its way
Dan Mitchell
>Let me know if it doesn't arrive.
Happy shopping!
Dan
Got iT. THANKS
