Raised Panel Door
Raised Panel Door
Raised Panel Door
Tom Rex in TX
>I�m making my first set of raised panel doors. I�m leaving 1/16� for expansion/contraction. Would it be a good idea to put foam peanuts in the grove to keep the panel from rattling? Or do you have another suggestion?
Thanks,
Tom
Re: Raised Panel Door
Ellis Walentine, Host
>A lot of people use compressible stuff -- foam, spaceballs, etc. -- to keep the panel centered, but I don't. If you make the tongue and groove a tight slip fit and the tongue is not beveled, you shouldn't have any rattle.
Regardless of whether you put strips of peanuts in the side grooves -- and depending on the width and current moisture content of your panels -- you might need to leave a little more headroom in the groove to guard against the possibility of the panel pushing the stiles apart during the humid season. One-sixteenth inch is pretty small, and when your peanuts reach their maximum compression, something else has to give, namely the stiles. OTOH, you need hardly any headroom in the top and bottom rails, where the endgrain part of the panel goes.
Lee Schierer - McKean, PA
>I wouldn't use peanuts as they compress and don't rebound 100%. Use the space balls or make your own by extruding silicone sealant on a sheet of waxed paper in a 1/4" bead, then chop it into useable lengths. I would leave a bit more room per side for expansion say 3/16"
Lee
>Good advice on the spacing and cushions.
You did not ask, but I would prefinish the panels. At least stain them and put on a primer/sealer coat. That way, if they shrink, you won't have a raw strip showing. And they may shrink and swell less if they are sealed all the way round.
AZ
>I think the rule of thumb for wood movement due to changes in humidity is 1/8 inch per foot. You split that on either side of the panel. For a narrow door, 1/16 per side might be adequte -- depends on the width of the panel.
If you make a shiplapped panel, measure the width of the entire space and divide the movement by the number of panels.
Of course, the movement varies by species of wood, but I think this is a good rule of thumb.
