200+ woodworking book reviews
Formica
Formica
Formica
Rod Rentz
>I have a friend with an old Airstream trailer. The kitchen table is formica which is in good shape but faded. He asked if there is any way it can be painted and I honestly don't know. Has anyone faced this problem?
Re: Formica
not a good fix
Bill Tindall, E.TN
>It is such an easy task to recover with laminate, that should be the preferred fix. But to answer your question...... after some scuff sanding it can be painted.
Re: Formica
Re: not a good fix
steve mackay
>Gotta agree. I'm think'n paint is going to wear off pretty fast from Formica. I'd do my best to talk him into replacing. He'd be happier in the long run.
Re: Formica
What kind of paint???
Ralph in Huntington Beach
>I'm in a new condo and the people who owned it before me smoked and must have burned a part of the high pressure laminate with a butt. They sanded it until they went through the color layer and it looks like crap. I don't have the resources to replace my counter tops at this time and only need to fix the one area, so I also wondered if it could be painted.
BUT, what kind of paint???
Re: Formica
Behr one-part water borne epoxy garage floor paint
Re: Formica
Polane paint *LINK*
Ellis Walentine, Host
>Back in my old contract furniture days, we used Polane paint to paint plastic laminate. It sticks fine and wears pretty well, but I would not recommend it for work surfaces, as the Formica under it is so dense and hard that you will eventually scratch off the paint.
I suggest you rough up the surface with a belt sander and then contact cement another piece of HPL right on top of the damaged surface.
Polane info
Re: Formica
Re: Polane paint
>The burn is right next to the sink and very visible...replacing a chunk of it might even look worse (especially if I do it). I've actually found a simple solution, I put a cutting board over the spot and that's where I stack my clean dishes.
The paint might just work for my needs.
Thanks!
Ralph
Re: Formica
Warning
>We did some of that on our old kitchen counter. Laminate is waterproof only until the finish layer is damaged, after which standing water can penetrate pretty impressively. When we pulled off our counter, there were spots that had long since turned from plywood (once a tree) back to soil.
Re: Formica
I have had it done... Wasn't real happy
Gary Camp, Bend, Oregon
>I had it done in a couple of restrooms, I let the Pros do it and I don't remember what they used, I would ask at a local pro paint store. I wasn't very pleased with the results but it was in a very high traffic area and the counters were cleaned mulitple times a day. I have recovered laminate counter tops in the past and better success. The key to recovering is CLEAN, CLEAN AND CLEAN AGAIN and when you think you have it clean enough, clean the surface one more time. Scuff sand with 80 or even 60 grit. While I am a fan of waterbased contact adhesives I might opt for a Solvent based contact here. I did use water based when I last recoverd a counter and the only real problem I had was poor adhesion in the area soap dispensers had been located, I just couldn't get years worth of soap out of the surface. It still lasted several years. Laminate and glue isn't that expensive if you do it yourself. Of course you may find the need for a new laminate trimmer and a few other tools but is that really a bad thing. You know the drill "Honey if I just had this tool I could redo the counter tops and save a lot of money."
glc
Re: Formica
Re: Formica
>My mother and sister painted their formica countertops. They still looked good after a year but then they changed to a Granite veneer so I can't give you a long life history. Personally I would just put more laminate on.
Re: Formica
Re: Warning
>The spot in question still seems impervious to water and has not shown any deterioration, other than being sanded out, in that area, but I am keeping an eye on it.
Re: Formica
Idea for Ralph
>My Aunt burned her counter top. Couldn't afford to replace it. I routed out a recess and inserted a piece of ceramic tile. She liked it so well she had me do a couple more just for fun. Bedded them in white silicon. If your burn is in the middle of the top this might work for you. Not so good on the edge.
Re: Formica
Re: Formica
>Locally there are people that "refinish" bath tubs. They use the same paint on countertops. Epoxy. In either case its only as good as the cleaning. Otherwise it peels right off in a sheet. Not great at best.
Better to cover it with another sheet of laminate.
Re: Formica
another trick
Bill Hammond, Oregon Coast
>Have you tried using the polish made for HPL? It will at least restore the sheen and perhaps some of the color if it's just a surface thing.
Re: Formica
Re: Idea for Ralph
>Great idea Barry, but you guessed it...right next to the sink! That's why I have a cutting board there with a wood dish rack on it.
I must have inspected the place five times, plus had a home inspection and never once thought about the place setting that was always there... Oh well, I still would have bought the place.
Tanks!
