Dehumidifier Lifetime
Howard in Bethesda
>I have been using Sears dehumidifiers in my basement shop and they last about 3-4 years. They are not running constantly. Has anyone found other brands that seem to last longer?
Thanks
Howard
Howard in Bethesda
Thanks
Howard
Re: Dehumidifier Lifetime
>I bought a house in the woods almost 6 years ago that came with a couple Sears dehumidifiers that were probably over 10 years old then. It had been a weekend house, so the units were only run a couple days a week. I have run one of them continuously since buying the place to keep the humidity below 50%, and added a new Sears unit a year ago to assist with the load. The old one keeps running like a champ, only recently starting to overflow, as the reservoir-full sensor is on the fritz. I just have to remember to empty it every other day or so.
Clint
Danby
Chicago Bob
>I am on my 3rd LG brand dehumidifier in 4 years - I sure glad that this brand has a decent return policy. These are not cheap units - in the range of $300 to $400 each.
I have had similar experience with "no name brands" from China in the past.
Good luck
Bob
Tom MacGregor
>Dehumidifiers, like any machine, last longer with a little routine preventive maintenance. If the evaporator coils become clogged with dust & debris efficiency is reduced and the compressor & fan have to work for longer periods. Keeping the inside of the unit blown out & wiped down makes them last longer, especially in basements and dusty environments.
Re: Woodshops & Dehumidifiers
>Don't mix too well. The main control circuit, the humidistat, is very sensitive to dust, and can become fused and inoperative if it gets dust in it. I replaced the "stats" on my old Fedders units (I run 2 50-pinters March to October) twice before wizing up. I now have HEPA filters mounted on the intakes that get changed every 2 months, and clean the interiors every 3 months. Mine get a workout as they need emptied twice a day (more than 10 gal.) when the house A/C is not running.
