Making some quasi- custom molding...
Alan Young
>I am working on some quasi custom molding for a set of bookcases. I don't have a shaper or fancy molding cutters but I thought I 'd show what you can be done with some stock moldings ...
A year and a half ago I built a set of bookcases.
New clients looking for bookcases liked that basic design but wanted to adapted it to their space and taste. Their design will also be painted but will have brass grills for doors and will have a set of four handcrafted tiles from Motawi set into the top case.
The tiles are 4" square and aprox 1/2" thick.
These tiles are more commonly associated with Arts and Crafts design but I think they'll add a bit of whimsy to this otherwise traditional design-but beyond that, it is the client's choice. I'll begin by "framing" the tiles in the reeded front face frames. I want most of the tile profile to be seen but it will need some frame work for support beyond the grout. Here's the look I'll be after---trimming will come later...
The reeded columns are made in two layers. The lower or back layer is a flat piece of 3/4" stock. For the top or front layer, I ripped and book matched stock moldings to glue up to the same over-all width. A plinth at the base and a 3/4" frame at the top will complete each piece.
Let's take a look at the molding. The stock comes milled on two sides-reeded or fluted as per choice. I'll be using the reeded side out.
If I edge glue these pieces together they are about 1/4 inch wider than the backer, so I ripped about 1/8th of an inch off one side of each piece.
Lets glue it up....Until I break down and built a Frank Klauz workbench I have the luxury of beating up on this one. I cobbled together a couple of scraps of poplar to make these handy risers. They are screwed to the bench.
I ran a bead of glue down the contact edges of the back side.
I took advantage of the dual profile of this molding by cuting off small sections and using the reverse profile as clamping blocks.
3/4" stock frames out the tile location at the top.
A bit of glue clean-up and trimming otherwise
One down three to go.....
I'll post more pictures as this project develops...
Alan
