Woodsuckers out there?
Dave Hammelef
>Ok, you all helped on the wood rack. Yes Ellis it will go to the ground. Looking at scraps and other ideas. Think Im going with the 2x4 approach but I have seen others with 3/4 ply on the outside and the 2x4 in the middle with the arms coming out. Pics to come when pinewood derby cars are done.
But getting things dug out, and fired up the woodsucker, forgot how load. Wondering if any are still out in use, and if anyone has attempted to put a silencer or ductwork on the outlet.
Re: Woodsuckers out there?
Dave Hammelef
>OH ya forgot to thank Dave Sparks, for his silencer below, just need to figure out how to get it attached.
Re: Woodsuckers out there? *LINK*
mdclor
>Dave,
I have a Woodsucker. I ran 6" S&D PVC to the various power tools. You can see some of the tubing at the below link. I am not certain how you would go about putting a muffler on one due to its design, but I would be sure happy to learn. It s loud even with 26dB ear muffs. Let me know if you have any other questions I might be able to answer.
HTH,
Merle
http://shoptours.org/shop_tours/files/merle-clor.html
How to attach a outlet duct to Woodsucker?
David Hammelef
>Thanks, Nice shop. Hopefully someone out there can help us. There has to be a way.
David G. Sparks
>Hi Merle,
You certainly have a nice shop. I have a question. How does your Woodsucker cyclone vent the air coming out of it? I only see a plastic bag and no filter. Thanks!
David
mdclor
>Thank you! At the top of the bag is a plenum that comes from the cyclone. The air/dust come down inside the plastic bag around the outside of the filter, then the air goes through the filter and up and out through the center of the filter, thereby exhausted toward the ceiling. The bottom of the hollow cylinder filter is sealed. I believe this is the reverse of must systems where the air/dust go down through the center of the filter. I hope I have explained this clearly.
Merle
David Sparks
>I understand now Merle. As far as adding a muffler, if you can come up with an adapter to connect the exhaust hole to pvc pipe you could hook it up to something like my el cheapo trashcan muffler that Ellis posted a sketch of a couple of days ago. I think you would be happy with the results.
David Hammelef
>"if you can come up with an adapter to connect the exhaust hole to pvc pipe "
And there is the million dollar question.
mdclor
>I seem to recall that the instructions advised against attaching exhaust duct work because of back pressure, but I could be wrong on that. I am surprised that there only seems to be two of here that have Woodsuckers. Here's hoping someone else will chime in.
Merle
David G. Sparks
>I just saw a photo of a guy's woodsucker with a clear plastic bag over the filter instead of a black bag like Merle has on his. I understand better how the cyclone works. I can also see that I don't have a clue how to hook a muffler up to it. Woodsucker has kind of an unusual design to say the least.
David Hammelef
>Yes it does. Built like a Tank. But have you ever tried to put racing strips on a tank?
