Dust collector muffler completed!
David G. Sparks
>A few days ago I asked for ideas on how to muffle the noise of my 2 hp dust collector blower's exhaust going outside. Thank you for your responses. I decided to make a muffler using a 35 gal. plastic trashcan. I drilled 1 3/8" holes around the perimeter of the can about 2" from the bottom to let air escape. I put a plywood disc with a 4" hole in the center inside the can squeezed in to about 6" from the bottom. I drilled a section of 4" SD full of 1/2" holes. After cutting a 4" hole in the can's plastic lid, I glued two PVC couplings and a short piece of pipe together connecting them through the hole. I sealed this with silicone to keep rain from leaking in. I filled the can with several layers of carpet padding standing on edge. I also put a piece on the plywood disc and crammed some in around the top of the other padding to keep noise from coming through the lid. I glued the piece of SD pipe with the holes drilled in it into the inside coupling on the lid. I slid the pipe down through the hole in the plywood disc. The end of the pipe extends just a little past the bottom of the plywood. After putting the lid back on the can, I hooked up my exhaust line. When I cut my 2 hp blower on now the exhaust noise is less than the noise coming from a clothes dryer vent. I'm happy with how it worked out. Thanks again.
