mortise
mortise
mortise
DP
>I recently finished the Arts and Craft Bed that was featured in Wood Magazine a couple years ago, and was going to start on the matching nightstands, only to find out that we are going to be grandparents for the first time! Well to say the least, our bedroom set is going to be put on hold while I build the 3 in 1 transition bed that Rockler sells.
The Arts and Craft Bed had only 4 mortise and tennons which I did by hand and they didn't pose too much of a problem. The transition bed has at least 104 mortise and tennons, therefore, I'm wondering about any opinions on what kind of mortise machine that I may want to purchase. I'm leaning towards Steel City only because I have their table saw and it is awesome.
Thank you in advance for any input.
Danny
Re: mortise
The Billion Dollars Question ! *LINK*
Bricofleur
>More than often the choice of a machine is a matter of personal preferences: The name, the color, the look, the accessories, the price, etc. Most of my tools are Delta because I like their tools and the reputation. My boddy woodworker has General Intl tools because he likes their tools and the reputation.
If you think your Steel-City tablesaw is awesome, I would say go for a Steel-City mortiser. Follow your instinct. No tool is perfect.
Most of available machines are alike and any won't stand far apart from the others.
According to me some mortises have to be done my hand, some others should be done with a hand held router, some on a router table and some to be cut with a hollow chisel mortiser.
Check this link to read an article on benchtop mortisers written by Roland Johnson. You may have to register to see the article, but it's free for 14 days. The article is from issue #178 of Fine Woodworking magazine.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Benchtop Hollow Chisel Mortiser
Re: mortise
Re: mortise *LINK*
Frank Mutchler
>Hi DP. I'm completing a Stickley table from Bob Lang's book that has around 80 mortise & tenon joints in it. I've used the RouterBoss and highly recommend it. It will cost 2 or 3 times what the bench mortiser costs but it will do so much more. It has a DRO that allows very precise positioning of the mortises. I have a very nice ShopFox bench mortiser that gathers dust now.
The RouterBoss
Re: mortise
Re: mortise
Rob Hix - King George, VA
>Hey Danny,
Woodworking has become a pursuit of a pleasure for me. I got tired of setting up the router or the drill press for doing mortises and then doing all of the tuning that is required afterward (either squaring up the mortise sides from the drill press, or rounding off the tennons for the router done mortises). I ordered a mortise chisel just to try them out and see how they worked. Given my pursuit of pleasure, I had much rather chop mine by hand. I love the process, and for me it is just as quick as with machines once it is all said and done. I do still use the table saw for the tenons.
That being said, if I were in a hurry, or if I were doing production work, I am sure I could make up some time with the proper jigs, and/or machines. Even in this case, I would use a router and jigs. I have used mortising machines before (several types), and I have enjoyed using NONE of them.
Just my $0.02, hope to have helped,
Rob Hix
Re: mortise
Re: mortise
>Good Afternoon DP,
I'm one of those people who do not enjoy hand chopping mortices. I find that in my hands, a plunge router hides the work and is a cumbersome, error prone arrangement. Others are far more capable in achieving clean and perfectly placed hand chopped and routed mortices. I needed to get the work done effectively with little fuss, and some fun. I bought a Shop Fox #W1671 morticer and fitted a HF cross slide vise at its base. I couldn't be happier with the result, and the price was right for sure. The fact that I have visual reference and adjustment capability to precisely mortice within the layout lines makes short accurate work of any morticing task. I have to agree with Serge's philosophy in choosing which brand to acquire. I had been able to test drive the Fisch, Delta, and Jet benchtop morticers and found each of them were capable. I bought the Shop Fox because at the time it was only a few more dollars more expensive, but was significantly more capable. They'll all do your job.
George
Re: mortise
Re: mortise
Fred Davis
>A doubly good afternoon to you George,
You did good when you installed the cross vise.
The Powermatic 719 A mortiser I have uses one and after struggling with some of the hold downs on bench mortisers , I couldn't be happier with this machine.
Yesterday I cut 32 identical mortices in the bottom stretchers of the chair I am fiddling with and after hogging out the waste on the drill press, it took about ten minutes to made mortices I could not achieve by hand in a day.
Today I will cut the same size and amount of mortices in the chair arms to recieve the legs, never built a chair with this many parts before. and it is a folding chair to boot.
FredD
Re: mortise
While we are at it... *LINK*
Bricofleur
>For those who already have a hollow chisel mortiser, or mortising machine, I want to share with you this jig I devised to hold the stock against the back fence of the machine so it won't move, but most important to me, put less stress on my left hand holding the stock. Not so funny getting old!
The link will lead you to all the details on my website.
Best,
Serge
Drill Press Overhead Routing Jig
Re: mortise
How is that different from the WoodRat?
Craig Daymon
>It looks like a copy...to the point I'm surprised they can make it.
I've seen the WoodRat video and it certainly is a capable machine. Though, if he wants square mortises, I don't think either the WoodRat or the Router Boss will do it.
