Impeding Seasoning of Wood
Paul Leuba - Hunt Valley, MD
>I have just purchased some unseasoned maple for turning Windsor chair legs, and it is a larger quantity than I can use within a few months. I purchased an entire log at the sawmill and it is being sawn into 8/4+ boards for me. I will rip 2" wide blanks from these boards for turning legs and stretchers.
Is there a technique that I can use to store the remaining boards in a way that will impede the seasoning process so that over time as I build chairs I will still have a stock of unseasoned wood for construction of the leg/stretcher assembly of the chairs?
Paul in Hunt Valley, MD
Re: Impeding Seasoning of Wood
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>There may be someone with more expertise than I, but I have my doubts. Maple is low on the list of decay resistance.
If you could sink it under water, and keep it cold enough, you could stop the decaying process.
However, if your goal is to just have the shrinkage of the wood to tighten the joints, you should go for drying it on down to below 24% MC. I believe that it the point where the decay is prevented, but most of the shrinkage is left.
I'd store it outside
Ellis Walentine, Host
>...under cover, of course, or in an open shed. In Maryland, it will probably air-dry down to around 14% and hover there until you bring it indoors or stick it in a solar lean-to or hot attic to really dry it well.
>Thank you, Ellis and Keith. I can and will store the boards outside under a tarp. I do not have an open shed or the ability to store the boards under water, so the covered stack will do fine.
>Paul, I hope you mean that you will use a tarp for a roof, after you stack and sticker it. If you don't, it will be growing hair in about two days and will be wasted.
If it is already sawn, and you have not stacked it yet, don't delay.
>I usually sticker and stack my green maple. If it air-dries, so what? I usually put it in my hot box after turning (after wrapping foil around the sensitive places).
I usually keep my white oak in log form. I either leave it submerged in a pool down by the creek or I leave it in damp sawdust mounds. The beavers usually leave it alone. I have gotten spalting in the outer layers and on the ends when I leave it in sawdust.
>Keith, the wood is currently in log form and will be cut into boards this coming week at the mill. I will stack and sticker it as soon as I get it. My plan is is cover the stack with a tarp to prevent water incursion. Are you saying that that is not a good practice? I do not have an open shed or any other means to readily put it under a roof.
Re: Impeding Seasoning of Wood *LINK*
>Paul, The wood is already quiet wet, as I am sure you are aware. If you don't start drying it pretty quickly, it will start to mold. Putting it under a tarp with no airflow, will hold the moisture too high, and prevent it from drying fast enough. If you live with it, you can tarp it during rain showers, but the rest of the time, it needs some air flow.
There are some good articles on this site. Here is a link to one.
http://www.woodcentral.com/articles/shop/articles_377.shtml
Air drying thick maple can be tricky. Even if you get the outside dry enough quickly to avoid the mold, taking it too slowly after it gets warm can lead to a gray cast inside, while it is nice and light on the outside. Good luck with this.
according to an authority
Bill Tindall, E.TN
>We had Curtis Buchannan for a club program a while back and someone asked this question. He puts his green wood in a freezer which keeps it from drying and molding.
>Thanks much, Keith!
Paul In Hunt Valley, MD
Fred Davis
>Paul ,
In the current issue of Fine WoodWorking, there is a very informative article on "Drying your own Lumber" by Dave Spacht who owns a hardwood sawmill in Eastern Pennslyvania.
This guy removes the myth and urban legend of drying, sticking , and storing lumber.
Aside from the common knowledge about this process , he shares a couple of neat ways to cover your pile once you have stacked it.
Elis may know this this person , when you see the pictures and read the text , you will understand that drying wood is simple , easy and rewarding.
FredD
Re: according to an authority
>Very interesting technique! That is a viable approach for a limited quantity given the size of my freezer. Perhaps enough for a few sets chair of chair legs.
>Thanks, Fred! I am going to my bookcase now and check that out.
Sinker log
Philip Duffy
>Paul, A famous Windsor chair maker/friend of mine keeps his stock of bending wood in his pond. He wraps it with a wt. to hold it under water for several months until needed. But, he uses completely dry hard maple for all his legs and stretchers. Phil
Bill Tindall, E.TN
>If you sell these chairs for what Curtis gets for them you could buy sufficient freezer space!! Personally it seemed to be an extreme amount of effort to gain the advantage of turning green wood as compared to air dried wood.
As others have mentioned maple can mold quickly and turn gray or black. You must either freeze it or get on with drying it at least below 25% MC or there abouts. Remember to use dry piling sticks and keep the rain off the pile.
Curtis splits his legs from log sections. Saves the saw bill.
Re: Sinker log
>That pond storage sure would keep it from drying out to soon.
I am fascinated by the fact that he uses thoroughly dry maple for the legs and stretchers. I was taught in the class I took last year that the legs should be unseasoned maple when fitting the tenons for the stretchers in order that over time when the wood seasons, the tenon holes will shrink around the tenons and make a joint that will not loosen. Using this system, when fitting the unseasoned maple legs into the holes drilled into the seat, the leg tenons are buried in a bucket of heated sand (150 degrees F.) for 15 - 20 minutues to dry and shrink them. This is intended to ensure a contiuing tight fit of the leg to seat joint as the legs ultimately dry to ambient conditions.
It's a bit of trouble, and if your Windsor chair making friend is using seasoned maple for the leg assemblies successfully, I may be going to a lot of trouble unnecessarily.
You are going through a bit of trouble..
>I've tried it both ways. IMO, you really don't have that much to worry about. With green wood, you get shrinkage around the tenon which locks the tenon in fairly tightly. With kiln dried wood, you may have the problem of seasonal variations eventually loosening the wood (after 100 years or so). I think that with modern adhesives, any loosening would be negligible.
Maybe we could do an accelerated test. Some of the Dunbar School of chair making thoughts are very mystique driven. I don't necessarily agree with them. I favor Curtis Buchanan's techniques.
Re: You are going through a bit of trouble..
Fred Davis
>Ah yes, Mike Dunbar,
that guy started a thread on the old American Woodworker Forum which consisted of his stating the true term for the angle on a chisel , plane iron, and such was a bezel , not a bevel , we got a lot of comments about that seemingly silly argument.
The ladies chat moderator (Handle was Carbide Saw) took Mike's Windsor chair making class and loved it , that is mostly all she did after that in woodworking.
FredD
oxygen exclusion
DizD
>If you're really looking for an alternative -there has been some work done in Europe on green log/lumber storage using a sealed cover to establish the anaerobic conditions necessary to prevent deterioration.
Use a Google search for this article to see an analysis of the technique. "Timber Storage � Log conservation under Oxygen Exclusion"
Although this deals with logs, other work I have seen shows it is applicable to sawn lumber.
>Thaks for the feedback. Now that I have the green lumber, I will try a few chairs with green maple legs and see how it works for me.
That is beautiful work on the Windsor settee.
Paul in Hunt Valley,MD
Re: oxygen exclusion
>Thank you! I will check that out.
DizD
>With the size material you are working with, it seems to me that you should be able to implement this concept using pvc pipe. Don't know for sure if any of this would work but if you put the material in a section of pipe and cemented end caps over each end, you would have a vessel which would not allow aerobic activity after the oxygen is depleted. Using clear pvc you would be able to visually monitor the material in lieu of having instrumentation to measure O2 level. Another thought would be to put dry ice into pipe before sealing.
