Making a Ferrule
Paul Storck
>I would like to make a ferrule out out copper or brass tubing for a file or awl handle. Any ideas as to how to taper or otherwise shape it where it meets the tool?
Making a Ferrule
Paul Storck
Re: Making a Ferrule
>Paul,
I've made them for turning tools out of copper, brass, and aluminum. I generally turn the wood to fit tightly, epoxy on the tubing, then turn the metal while the handle is still on the wood lathe to shape, smooth, and taper a bit. A good way is to use large copper or brass pipe or hydraulic fittings - if you get threaded fittings they can be screwed onto the wooden handle, then shaped on the lathe if desired. I've seen some just left as purchased and just polished a bit.
Woodturners often make handles, so you might ask on the Turning forum or check the archives for past threads. I remember a number of discussions, some with pictures.
Pat Riley
>I always use brass plumbing nipples from the local borg. Brass pipe is generally sold in lengths between 2 and 6 inches long and it comes in several very usable diameters.
The nice thing about brass plumbing pipe is that the walls are quite thick. This allows for a rather extreme taper. I always taper the piece after it is glued in place and while it is turning on the lathe. Files can be used, as well as sandpaper, but I find that good high speed steel tools cut brass on the lathe just as well as wood.
You could also do it with a file in a drill or drill press if you dont have a lathe.
Shoot me a message off line if you have any questions.
Pat
>My favorite ferrule material for awls is a brass screw thread to solder pipe adaptor. It has screw threads on one side and tapers down to a soldered pipe fitting. When you turn the hex part away it gives you a really nice tapered appearance.
Paul Storck
>I want to thank you guys for your great ideas and methods. Tomorrow I'll head to the store to choose some materials and see what I can do.
Paul Storck
Fred Davis
>While they are to thin to taper , used as is for files and chisels , copper caps for copper tubing do a nice fast job.
FredD
>Paul just go to the bins that have all the brass fittings. I've use a lot of different ones. If they are thick you can turn the hex's off or even turn threads away. I have only once run into one that was too hard to turn. You can anneal these by heating them red hot and then quenching them in water. This is the opposite of what happens when you do that to steel. It makes them soft enough to turn. Copper will do the same thing and can be annealed the same way. I have not run into copper that would not turn easily.
