My Only Kitchen, My Initial thoughts..
Jim Rahbe
>Lee,
So far I have made one set of kitchen cabinets and they were the frameless, euro style. Here are some of the things that I did not fully understand before setting off to build them.
1. When you install face-frame cabinets between two walls, you can make the ends wider and scribe them to the walls for a perfect fit. With frameless cabinets you can add a spacer, but it will never be seamless.
2. With face-frame cabinets, the doors are generally set in from the edge and inch or so. With a frameless cabinet, the space is more like a � inch. Doors on cabinets that are installed against a wall will not open all the way to allow for sliding trays etc.
3. With face-frame cabinets the edge of the plywood or particleboard are covered. With frameless cabinets, you generally use Edgebanding tape of some type. I found the edgebanding to be expensive to buy, a pain to install, and it just has a �cheap� look to it. I even bought a hot air edgebander and the edge and end trimmers, but it still took me most of the project to get even reasonable good at installing it. So far, so good, but I�m not at all convinced as to how long it will be before pieces will start to fall off.
4. I like the open box at the bottom of each cabinet, when using the face-frame design, as it gives you a place to hide under-cabinet lighting. You don�t get that feature with the standard frameless design. You can add a piece of trim, but in my mind, it does not look right.
5. I really do like the 32mm system. The only downside is that you have to buy or, as in my case, make a pretty accurate drilling jig to make the necessary holes. The other day some one here was asking about installing drawer slides in kitchen cabinets. Using the 32mm system, nothing could be easier, as all the holes are predrilled.
6. I also like the idea of no center stile, especially on cabinets that have sinks. Really makes getting in and out very easy.
Please remember this is my one and only experience with anything other than shop cabinets, so there may be answers to all my problems that I am just not aware of.
Jim R.
