ADVERTISE HERE - FREE TRIAL
Two refinish jobs (pics)
GolfSteve in Calgary
>I made, and French polished, a small side table several years ago. I don�t know if the polish was bad, my technique was bad, or if I expected too much from a shellac finish, but the finish did not hold up at all. The finish seemed very soft, and would take on an imprint of whatever was sitting on the top, even a fabric coaster. The shellac finish on the aprons, legs, and drawers is holding up well, so, I decided to just refinish the top.
Here�s a picture of the original table:
I was surprised when removing the top to see the color difference on the underside of the top � the areas exposed to sunlight are very noticeable:
I sanded down the top and refinished it with dyed Target wb lacquer. It took a bit of fiddling to get the colour of the top to match the rest of the table.
And my daughter has already put the first scratches on the top:
I�ve refinished a coffee table with the same finish, and it has held up well to my daughter�s gentle abuse so far, so I�m hoping for the best with this table:
I had a bit of spraying practice around Christmastime � we were given an old beaten up dollhouse of unknown original. I cleaned it up and sprayed it with white shellac (BIN). I didn't have great success spraying the interior of the rooms. My daughter plays with it for hours:
Re: Two refinish jobs (pics)
Great Work, Steve
>I like the tables, too. :<)
George
Very nice...
Bricofleur
>Congrats Steve. I'm not a fan of "glass-like" finish, but I must admit you did a pretty good job. I like the well proportionned table too.
Your daughter is very charming. I kept a copy of the doll house to get inspired to build one for my 2 yo grand-daughter (trouble in sight with her 4 yo brother!!!).
Thanks.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Gloss-s-s-s-y!
Ellis Walentine, Host
>That's a finish my old dad would have loved. It's a tough one to ever get perfect, because the reflections point up the tiniest imperfections, and those change over time. It looks like you've done a really masterful job. Good work.
Your little girl is a darling, by the way.
Nice Work, Next Time
>Try some General Finishes Enduro clear with added cross linker. Doesn't burn in as well as USL, but the cross-linker gives a film that's super tough and scratch resistant. I used it on this coffee table in my billiards/"wreck" room and there's not a mark on it after three parties.
[Of course nobody was dancing on this table, that I know of]
Stealth Gloat?
mdclor
>I am trying to decide if this post was a stealth gloat about the quality of your wood work or your daughter or both. Very nice on all counts!
Merle
Re: A question
pecker
>I bought a gallon of Target's USL gloss, but haven't used any yet.
I was under the impression that it would need to be rubbed out to get a perfectly smooth, yet high gloss appearance..
Could you explain what you did to accomplish that look? It's not just a couple sprayed on coats, is it?
Thanks.
Flattening & polishing
>I'm not that great at spraying yet. This was my second best spray job and it would have been a nearly perfect satin finish right off the gun - except some boogers flew out of the gun on my final coat and caused me much distress. However, the boogers burned in well, and they sanded out perfect.
1. I sanded down to bare wood to remove the old finish. For some reason the cherry around the glue line remained quite a bit darker than the freshly sanded cherry, so that is why you can clearly see the glue line, which was originally invisible. I'm hoping that the line will disappear as the rest of the top darkens.
2. I sealed the top with alcohol based dewaxed garnet shellac.
3. I sprayed several coats of tinted shellac to get the colour I wanted. I love using dyes! I think I mostly used Transtint Dark Vintage Maple, and ColorFx Burnt Umber which combined with the garnet shellac converted the raw salmon of the freshly sanded wood to match the existing darked cherry.
4. I sealed the tinted shellac in with another two coats of shellac, then sanded very lightly (with a sanding block) to flatten the surface and remove imperfections (*).
5. I sprayed ~5 to 8 coats of the Target USL. The top actually looked pretty good straight off the gun, except for the boogers.
6. I let the top sit for 4-5 weeks to harden (plus I was busy doing other stuff and was peeved about the boogers).
7. I wet-sanded the top with 1000 grit automotive sandpaper and low odour paint thinner. I used a sanding block for this step, which removed the boogers and flattened the surface. I sanded until all the glossy spots were removed, and was extremely careful to not sand through the USL into the shellac, especially near the edges. This sanding took about one nerve-wracking hour.
8. I polished the top with Menzerna #16 Polish and a bit of water - this leaves a semi-gloss finish. I polished by hand (no power), and this took about five minutes for the edges and top of the top. This stuff works very fast.
9. I polished the top with Menzerna Intensive Polish and a bit of water. I spent about 15 minutes by hand, but then cheated a bit and used a buffing pad on my ROS because there were a few persistent scratches that I did not remove properly in step #8. If you look at the pictures, you can see the reflections in the finish which should be straight lines, are "wavy" - this is a sign that I was a uneven in this power polishing. It's impossible to detect the slight imperfections by hand, but you can see the waviness in the reflections.
Using the polish with the ROS is kind of like letting your two year old daughter make whipped cream with an electric beater by herself, so make sure you put away anything that you don't want splattered with polish.
I find the finish looks cloudy after the power buffing, so I spent about two minutes buffing by hand (using blue paper towers and the intensive polish) at the end, to bring up a perfect shine. The Menzerna polishes are great.
The reason I polish to high gloss is that I really don't like the look of rubbed out finishes - they just look scratchy to me. Some day I'll try spraying some "Satin" USL instead of the "Gloss", and see if I can avoid the high gloss look while getting the perfect surface finish that I want.
(*) ps. I had to repeat steps 1 to 4 THREE times because I was out of practice and sanded through the dyed shellac TWICE, revealing the bare wood below. What an idiot.
