Heavy duty shelves for theatre equipment?
>The new theatre manager has asked me to build several sets of shelves for lighting equipment (lights, cables, "wyes", etc.). They will be in an out of the way room, so they don't have to look pretty.
My current thought is to take some 5/8" or 3/4" BCX plywood and rip it to 15 3/4". I would use this to skin a 2 x 4 shelf frame (15 3/4" deep and 6-8' long with spacers at 2' intervals). I was going to cut a 4 1/4" dado in several (3 or 4) pressure treated 4 x 4s and use those as the front supports. I was going to use Tapcons to screw the back of the 2 x 4 shelf frame into the cinder block wall.
The roof is currently leaking (it will be replaced one of these days) - so I do have some problem with water on the floor. I'll be putting the shelves on interior walls so the water won't drip on the equipment. I'm planning on putting the bottom of the 4 x 4s on plastic spacer blocks.
Anyone else have any other thoughts or ideas? The budget for shelving is sort of low, so we don't want to invest in high dollar stuff. I figure I could install two sets of fairly long shelves for under $150 if I build them this way.
TIA
Re: Heavy duty shelves for theatre equipment?
Re: Here's some inspiration
Bricofleur
>When I saw this wood rack (can't remember where) I saved the picture for future reference since it was so clever.
You can get inspiration from it and swap 2"X4" by 2"X3" or even 1"X3", and so on. Since the budget is restricted, I would recommand making the shelves with 1"X boards flat on the support brakets.
If the roof is leaking, this unit being free standing can sit anywhere in the room.
Best,
Serge
When I need heavy duty shelving
Gary Camp, Bend, Oregon
>I use 2x4 uprights with 2x2 screwed to them ladder style and 3/4" CDX or CC-plugged 32" long screwed to the "ladder rungs" For longer shelves I would screw a front and back edge, 1 or 1-1/2 inches tall to the shelves or use 2 2x6 and 1 2x4 spaced correctly. At todays prices here in Bend it would be cheaper to use 2x material for shelve than it would be to use plywood. If you want even more heavy duty shelves through bolt the "rungs" to the uprights. Quick, sturdy and not to expensive.
glc
