How to dovetail round wood column
Woodie49
>I'm looking for information on how to make Dovetails in a round wood Column for legs? Any Jigs, Ideas?
Thanks
Re: How to dovetail round wood column
Roy Girolami------WebKitFormBoundarywFn+9eH9wAEIGq
>Check out the New Yankee Workshop. Norm has done this in a project. I followed his procedure on a tilt-top table I made and it works very well to put dovetails where you want them.
Roy Girolami
Apex, NC
I have done it a number of times.......
>I'm not a hand tool guy, so if you want that method, post this on the Hand Tool forum.
I have done it two different ways. One on the lathe and the other on a router table.
My lathe has an indexing head, so that makes setting the angles for the legs easy. I made a "box" that locks into the bed of the lathe and it will slide along the ways. It has a top with a slot about 1 1/2" wide in it. There is a second overlay top that has a narrow slot, that fits one of the guide bushings on the router. I Thread the column through the box and lock it in place. Then I use the router to cut a "flat" on the column that matches the butt of the leg. Rotate the column to the next position and cut another flat. (Rotate ninety degrees for four legs and 120 degrees for three. I like three because they will always sit flat.) Then I put the overlay top on and adjust the dovetail bit to cut as deep as it will and cut the dovetails in the center of the flats. If the dovetails are too large to cut in a single pass, I put a straight bit in the router and hog out the center for the cut first and then come back with the DT bit.
I make my columns with a ring on them or a reduced diameter for the legs, so that there is a should to tell me where to stop the cuts for the legs. This hides the top of the leg where it butts into the column.
Using the same bit or one with an identical angle I cut the DT tenon on the legs on the router table. At this point I make sure the legs have flat surfaces on both sides and are square on the ends. (Watch the grain angle, it should be long grain through the skinniest part of the legs.) I put a sacrificial fence on the router table and bury the DT bit in it. I make a pass on both sides of the leg. Making sure the height of this DT is about a 1/32" less than the depth of the socket. Keep revealing more of the bit, making the cuts deeper until I get the DT tenon to just slip into the socket. I use a rasp to shape the top of the DT tenon to mate into the top of the socket. Just be careful not to file into the shoulders or it will show. Shape, taper, sculpt the legs after you cut the DT's.
The flat on the column is to match the butt of the leg. That way you don't have to under cut the shoulders on the legs to match the curvature of the column.
To cut the slots on a router table, I made triangles for fit on both ends of my column. I put a screw in the center and a couple of brads to hold them from rotating. I nipped the corners off the triangles neatly so that they would ride nicely on the fence, without tucking under. I put a stop block on fence and with the bit low in the table milled off the flats. Sneaking up on the height until I got the flat I wanted. Had to move the fence back and forth, but that was pretty casual. Then set the bit to the height of the socket and centered on the flat and milled the slots. Like many things the set up was tedious. I made the triangle out of 1/2" baltic birch so they would not fall apart. Triangles were sort of a head scratcher. Squares would give you four legs and much less head scratching. One problem with this is that you router table has to be big enough to support both ends of the column. Mine were small and I still had to extend the table and the fence.
I made one set that were looser than I wanted and glued them with epoxy. One little table I threw together really quickly to show some one the set up was really sloppy so I glued a strip of card board in the slot. This whole thing was almost a joke, using scraps. They are still using the table.
Re: How to dovetail round wood column *LINK*
Bricofleur
>This morning I received a NewsLetter from American Woodworker magazine and was included a link to a plan for a Shaker Stand, showing the "How to" you are looking for. The method is similar to which Norm Abram used in his TV program "The New Yankee Workshop". Check particularly on page 7. And take the opportunity to sign up to receive these interesting NewsLetters.
Be patient and you'll do it right.
Best,
Serge
American Woodworker Magazine Shaker Stand
Dave Bair, Eaton Rapids, MI
>I've never used one but MCLS (and probably others) make a rounter bit called a "candle stand" bit. It cuts both the dovetail and the flat in the same operation.
Fred Davis
>Woodie ,
I have made several Duncan Phyfe type drop leaf tables and the method I used to attach the legs while not a dovetail seems easier and has less hassle then a dovetail joint and because the wood removal doesn't leave weak edges I think it is inherently a stronger joint.
Either using the column you turned for the pedestal or making a separate one equal in diameter , mount it in the lathe and tack some 80 grit sandpaper evenly to it and while holding the legs on the tool rest run the ends into the column until you have a recess that fits the roundness of the column and attach each leg with two or three depending on the leg size 3/4" dowels.
This method was taught to me by my woodshop teacher in high school on the first project I did , that was advanced in skill and technique requirements.
The guy was really a class act and directly responsible for getting me into woodwork and fondly remembered by hundreds of his students.
FredD
An added suggestion.......
>This Article shows a box like jig to hold the leg while doing the various routing steps. I like the idea, but I would suggest making the top of the box out of 1/4" plywood or masonite. Keep it thin so the collect for the router can be as close to the leg as possible. If you extend a 1/4" router bit too far, you will get some whip in the shaft. If the bit whips the slots may be inaccurate and vary from one to the other. The top of the box does little to support the router, it ride on the edges of the box (Indirectly). Or, use a bit with a 1/2" shaft.
