Laminate Springback Calcs Article
Sgian Dubh
>I have just added a new short article to my website on the subject of calculating laminate sprinback to my website. It may be useful to other forum users. It is a PDF document less than 50kb.
There is also a bit of cross-posting, eg, over at the Hand Tools section and at a couple of other forums. Slainte.
Re: Laminate Springback Calcs Article
question
Bill Tindall, E.TN
>In your discussion you state that the thickness of the individual pieces affects spring back, yet thickness is not a variable in any of the equations used to calculate spring back. Please clarify.
Re: question
Sgian Dubh
>Bill, I think it is a weakness inherent in all the formulae I have come across over the years. That is why I state early in the text that I don't give any of them too much credence and frequently resort to intuitive guesswork. Slainte.
Jesper, Denmark
Re: question
Jesper, Denmark
>There is an old rule-of-thumb in wooden boatbuilding that says that a seven layer steam-bent lamination does not spring back.
Mostly these are deck beams on pleasure yachts. As they are usually fastened at both ends to something rather solid, it is of no real consequence.
The usual procedure is to steam, then bend in a form. Let cool asnd partly dry, then glue in the same form.
