Finishing dark walnut
David Dircksen
>I'm making a couple of aggravation boards made of dark walnut that my dad had laying around for about 30 years,I was wandering if you just rub on poly or do somthing else to finish it. Thanks
Re: Finishing dark walnut
Jim DeLaney, Austintown, Ohio
>I use garnet shallac. It really brings out the beauty of the walnut.
Jim D.
>I like to use a dark grain filler before applying finish.
I don't know what an aggravation board is, but a True Oil finish, often used for gunstocks, can be durable and beautiful. We used it recently on a walnut rifle stock.
Jim Dillon
>David,
On a limited basis, I've had luck with a thin coat of orange dewaxed shellac (1# cut, wiped on) followed by several coates of Tried and True oil/varnish blend.
Jim
Re: Finishing dark walnut - aggrivation board?
Carol - now back in Dubuque, IA
>What is it?
With regard to walnut, I wipe on a little golden oak stain to bring our the lighter highlights and then spray lacquer.
Fred Davis
>A really great game for pardners on a board bored to hold marbles and moves dictated by a roll of dice.
Had be known to stay up with Aunt and Uncle until wee hours of the morning playing that game.
Board we used was one we made out of particle board, Walnut would be nice.
Shellac probably won't stand up to the pounding of dice cups on the board and moving marbles when eveybody is excited.
Oiled Walnut with Watco -Denis Danish oil would enhance the color and not chip with the playing, while protecting the board somewhat, when the finish gets shabby, oil it again.
FredD
Aggravation board?
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I am not sure what it is either, but I'll take a guess.
I would think it is a nicely formed board that fits the hand and shoulder, with a tube on the other end. It opens in the middle somewhere to take a capsule which is delivered to those aggravating varmints when you pull the little activator switch. Maybe you guys are talking about the same thing. he he.
