Quieting dust collector exhaust
David Sparks
>I recently got my Oneida V3000 up and running. I'm using my old 2 hp blower to suck dust from my scroll saws. I've run the exhaust pipe outside and am trying to come up with the least expensive way to reduce the outside exhaust noise. My exhaust pipe is 4" SD PVC. I'm thinking about making a muffler using more 4" pipe with a bunch of holes drilled in it running through a piece of 6" SD PVC packed with fiberglass. Do any of you have a better suggestion? I read somewhere about using flexible HVAC duct, but I don't remember where I saw it. Thanks in advance for your help.
Re: Quieting dust collector exhaust
Hamish
>David, I remember seeing sound dampeners for air conditioning at the back of a theatre. They were constructed by having the extracted air passing between large parallel panels or boards which were covered on both sides with softish sponge. The distance between them was as far as I can remember, was about 8"-10" inches.
Perhaps you could have a look around your neighbourhood for something similar.
Regards, Hamish.
David Sparks
>Thank you, Hamish. The idea makes sense. I will look around.
Bricofleur
>David, in my previous house we had an efficient muffler on the central vac system. It was installed just before getting out through the concrete foundation. The outside of the muffler was PVC, a larger diameter than the vac pipes, but the inside was walled with flexible styrofoam to the same diameter of the vac pipes. You could try filling the inside walls of a 6" PVC pipe, glue end caps and reducers to the 4" of your exhaust. Big box stores sell styrofoam pads in many thicknesses. Should not cost a fortune to try.
See picture of what I found on the web at dealtime.com to give you an idea.
Best,
Serge
Ken Krawford
>David,
Here's a link to some plans I used to make a DC muffler. I can't really tell you if it helped because I have been using it since I first built my cyclone and have never run it without.
http://billpentz.com/woodworking/cyclone/Muffler.cfm
Fred Davis
>Onieda sold me a muffler that connected between the cyclone and the bag house , which reduced the noise by (their estimate) about 10 or 12 decibels.
Maybe they still have one that fits your setup.
FredD
Darin in Victoria
>How are you finding the suction and dust separation on the V3000? I'm thinking about buying this model, but haven't heard on how it performs. I'm hoping that you'll tell me there's very little coming through the filter :)
David Sparks
>I haven't used my V3000 a lot yet. I sucked up a bunch of sawdust out of the base of my table saw and couldn't find any dust in the pan below the filter. The sales rep at Oneida told me the V series cyclones are very good at separating out the fine dust. So far it seems he's right.
Darin in Victoria
>Salespeople always seem to say good things about their products LOL. However, I have just been in contact with a person who also bought a V3000 and he is really happy with the separation. He said that he's filled the drum several times and has only had to wipe the bottom of the filter can. So it looks like the Oneida rep was telling the truth :)
