Building Cabinets - Installing drawer slides
Terry Alexander
>After much hand-wringing, gnashing of teeth, and pricing, we have decided to build our own kitchen cabinets. Our kitchen is not that big and I will get to "practice" on 2 vanities before the kitchen job.
I "think" I am qualified enough to build the cabinets. I KNOW my wife is qualified to do the finish. She finishes whatever I make (I hate that part) and she is great at it.
My greatest fear is installing the drawer slides. I have never done it...period. I have built a lot of cabinets...but I just let the drawers float in the opening.
My fears? Seems like if you are off just a 1/16"...in any dimension.... you are hosed.
Appears you can build a perfect cabinet and drawer and then install the slides too high...too low...not level.......just scares the he$$ out of me.
Having said/typed that....any suggestions from you pros on how I should proceed?
As always...TIA
Terry Alexander in West Texas
Re: Building Cabinets - Installing drawer slides
Dave Bair, Eaton Rapids, MI
>"Appears you can build a perfect cabinet and drawer and then install the slides too high...too low...not level"
True...however, you can also adjust, reinstall, etc., until you get it perfect. There are installation templates for most of the common slides that will help you do a better job. Just make sure you know what the hardware's dimensional requirements are before you put saw to wood. A drawer box that's too big for your hardware is difficult to modify.
I recently completed our kitchen and it's well worth the effort, provided you are not on a tight time schedule or deadline. I ended up building and installing mine piece-meal because I didn't realize how much space assembled cabinets would take up in the shop.
Re: Building Cabinets - Installing drawer slides *LINK*
Bricofleur
>Terry, here is my own fool proof method of work: First I install the slides on the cabinet sides, then, only then, I take exact measurements between the slides, and then, only then, I cut to size the drawer bottom, and then, only then, I add the sides to the bottom. This was for the Melamine drawers I made in my basement shop.
For kichen cabinets I believe you won't use Melamine so I suggest you install the drawer slides in the cabinet and then cut to size a template from 1/4" ply or MDF or hardboard and then, only then, take exact measurements of the template to build your drawers. The template should glide smoothly on the slides.
If your cabinet sides are parallel, you will need only only template. If not, you will need to make a template for each drawer location.
I built 15 drawers using this method, and I can say it's fool proof.
Best,
Serge
Atelier du Bricoleur
Dave Anderson (PacNW)
>Wood Magazine has a great video on installing ful extention drawer slides.
Very very good link! Thank you!
Terry Alexander
Jim Dillon
>Terry,
Yes, I was nervous too before I redid our kitchen with all the sliders as I had no experience at all installing them. Just take your time, read any instructions that came with the sliders, and have at it. It is good that you can practice on your vanity. To get the height of each slider the same, I cut two pieces of scrap plywood, say 1-2 inches wide and the exact height of your top-most drawer in the cabinet. Place the slide on top of each piece of plywood (one to the front and one to the rear), and screw the slide in place while remaining cognizant of the slide's front to rear placement. Do the same for the slide on the other side. Then cut the pieces of plywood to the exact height of your drawer that is beneath the top drawer (if there is one) and do the very same thing. Works like a champ. Naturally, this assumes your cabinets are built and are reasonably square, although in thinking about this I guess you could do this on unassembled cabinets by putting a "hook" on the end of the plywood guides. Hope this helps.
Jim
Fred Davis
>Terry ,
Having been a cabinet maker for years I can tell you , the job is simple to accurately install a good grade of drawer slides.
I prefer side mounted slides to all others and the brand I use is Accuride , which is available at all wood working suppliers and some hardwares and directly from Accuride if you have a business.
These slides have vertical and side adjustment which is handy , especially the vertical aspect.
For Kitchen cabinets use , I use fully extendable rated for 100 pounds which is a medium grade and will handle any drawer load you would expect to find in a Kitchen.
I also use them for roll out shelves on the bottom cabinets which makes a woman grateful, instead of using fixed shelves thru out the cabinets.
Build your cabinet square and the drawer compartment sides parallel, not doing this will frustrate your slide installation no end .
Make and install the drawer face frame and if you use rails between the drawers , most kitchen setups do, after you have done this , with the divider being flush with inside of the drawer opening on one side and the inside of the end of the cabinet furred out to the inside of the other end of the drawer opening , your ready to mark slide locations, assuming you have already made the drawerbox exactly one inch narrower then the draw opening.
This measurement accommodates the standard 1/2" clearance needed for the slide on each side of the drawer.
Cut a small stick about 3/4" square and long enough to reach from the inside bottom of the cabinet to about the height of the top ,using this "story pole" hold it vertically inside of the face frame of the draw cabinet and mark the height of each rail on the stick and then using it in the same manner transfer the rail height opening to the back of the drawer case.
These two marks are the height of the bottom of the slides and bottom of the drawer box.
Take the Accuride slides apart and you will notice that the slide that attaches to the drawer box will have a row of screw holes that will correspond to a line you draw on the side of the drawer about one and 1/8" above the bottom of the drawer.
Fasten the slide to the drawer box ,using the pencil line showing in each screw hole and it's mating part to the inside of the drawer compartment using the two marks you made for height.
Depending on the style of drawer you make , for instance a 3/8ths" lipped front , you will need to hold the slide back from the front of the face frame at least 3/8ths" so the drawer will shut completely.
When your screwing the cabinet slide on , rest it on the bottom of the face frame drawer opening and tack a temporary nail at the back mark to rest it while you fastening the slide.
With Accuride brand of slides you wil note that the slide on the drawer side is held back about 1/8th " from the inside of the front.
Why this is done becomes apparent when you ned to use the vertical adjustment cam.
I use a little 1/8th thick chip inserted between the slide end and the back of the drawer front to maintain this distance and then take
it out after the slide is fasten on the drawer side.
Before you install the slides make sure that the drawer box is a inch narrower then your drawer opening , this measurement should be within 1/32 of a inch or less , preferably less.
Before you install all of the slides , do one drawer and try that out for size , if it works smoothly , then your good to go.
I know this seems long , read it more then once , it's faster then doing a batch of drawers over, remember to measure accurately and double check the drawer clearance and once you do a couple , you will get the hang of it.
Most brands of side mount slides install in a very similar manner, regardless of brand, the rating weight wise is the indicator to look for and naturally a 22 inch long slide if your kitchen cabinets conform to a standard depth of 24 inches and 18 inches long for a standard vanity depth of twenty one inches.
If you get lost or confused , email me , I am just around the corner , in a manner of speaking . ;-))
I have included a link to our Kitchen I did a couple of years ago and you can see the drawer slide very plainly in the close up.
FredD
http://picasaweb.google.com/lh/photo/BxoRU1A8z9rtXt1VNLzQmg?authkey=Gv1sRgCPW6-YCYlduLoAE&feat=directlink
Very good, Let me reinforce......
>Fred's description is very good. Read it over and over. Print it out and walk through the first couple.
Let me just add a couple of things. Make the cabinets and drawers accurately and square. Can't stress enough how much out of square out of dimension work will screw up trying to install drawer slides. And, if you make an error on the drawers, it is better if they are undersized rather than over sized. If you make them a 1/16 too small, you can shim the openings with card board. If they are a 1/4 too small, you can shim the openings with hardboard. Or something. But if the drawer is too wide, there is H to pay. Something has to get cut down. (None of this is hard or extraordinary, its just taking the time to get it right.) Once you get past the learning curve this will be straight forward.
And a final point: You didn't ask or even mention how you were going to make the drawers or even if you were making them yourself, but I have a friend in the cabinet business who has been doing kitchens for over thirty years. Nearly all the drawers are simple but joints. No dovetails, no lock rabbets, just butted, glued, and stapled. He has never had a call back. Out of thousands of drawers and pull out trays, not one has come back because of joint failure. He has even torn out some kitchens he did years ago and replaced them because they remodeled and seen first hand that the drawers held up.
Jim Dillon
>Fred,
Superb post with lots of good practical advice based on your extensive experience. I too have had good luck with the Accuride slides. Thanks for taking the time to post and helping Terry out.
Jim
Fred Davis
>I like to think that's why we are here Jim ;-))
FredD
