Shopmade D-handle Router Base *LINK*
Bricofleur
>Take a look at my shopmade D-handle router base. I've been thinking about that for months. I was inspired by Carol Reed's design. The sub-base is made out of 3/8"-thick Plexiglass and the D-handle is nothing but two pieces of scrap plywood glued together and shaped like my hand saw. Two short afternoons spent in the shop and it was done. I wonder why I waited so long. No more tipping in sight when milling edges with this router.
Take a look at the details and short videos on my website and build you own (see link below).
By making it myself I saved at least $100 CAN. When retired, you don't have much money... but you have more time!
Best,
Serge
Re: Shopmade D-handle Router Base *LINK*
paul waddle
>Excellent work! maybe sand off the sharp corners and give it a deserving couple of coats of poly..or just send me the proto type. he he. pw
Bricofleur
>Paul, no way I will separate from my new D-handle router base!!! It's "hot". You will definitely have to make one by yourself!!!
I'm not even missing the trigger switch. I will consider making a foot switch instead. I already have an idea on that, which I will share when done.
Thanks for your suggestion about the couple of coats of poly, but I like the feel of the wood in my hand.
Best,
Serge
PS: All sharpe edges have been sanded smooth. It's a tool afterall!!!
Atelier du Bricoleur
>Good Aftertnoon Serge,
That is a very nice modification. I did one similar to yours about three years ago, based on one crafted by Hoa Dinh. Hoa even sent me the plexiglass. I did mine of cherry. My #3 son liked it so much I made another for him.
As a refinement, I'm going a step further and will sit my shop made D handle atop a P+C sub-Base. My present configuration will not accept standard P+C template guides, necessary for when I do dovetails and box joints with a jig.
I wish I had considered doing that from the start. However, the shop made D Handle is a nice, useful piece of hardware which I use fairly often.
George
Bricofleur
>Thanks George.
When I cut and shaped the Plexiglass for my shopmade D-handle base, I in fact cut two having in mind to make a second one that will accept my guide bushings set (from Oak-Park). On scraps I will check which Forstner bits I should use for the recess and the through hole and then drill a centered pilot hole to get it right. Since I'm in no rush for this second base, it should end up... perfect! We'll see.
Best,
Serge
John in Calgary
>I like it, I've been meaning to build one of these for a while.
Now how about adding a loop to feed the plug through near the handle so that as you turn the motor in the housing, the cord always exits at the same spot?
John
Bricofleur
>Good idea John,
What about a hook screw on the wooden handle as shown on the picture. There would be enough room for the cord to flex I believe.
I must admit that the cord doesn't bother me while routing. But I may give it a try though.
Best,
Serge
Its Good To Reach Accord
I was anxious to try it !
Bricofleur
>I predrilled and installed a screw hook. I chose the right size so the cord will stay put. I had to bent the hook closed a little. Boy this stuff is hard! I didn't try routing with this new setup but I tried several manipulations and... I like it.
Thanks for your input John.
Best,
Serge
Re: I named it a 'BigFoot' in my book
Carol - now back in Dubuque, IA
>Some thoughts from the originator:
I tried the cord hook, and found it cumbersome. There were too many times I wanted the cord elsewhere. When the cord and the handle needed to be in close proximity, I simply included it in my grip of the handle. If a time comes where you want the cord 'fixed' in that place, temporarily simply thread it through the hand hole.
With regard to fitting collars into it, here is what I did.
Remember the concept of center. Mark center the best you can on the Plexiglass (acrylic). (BTW, don't use Lexan or polycarbonate. It bends!) Drill a 1/4" hole at that point. Then insert a 1/4" straight bit in the collet on the router. Drop the bit into the drilled hole. Do NOT turn the router on or even have it plugged in.
Now mark the screw mounting holes using transfer punches (around $10 from HF for a whole set). Set aside the router. Drill the appropriate sized holes for mounting your router. Do NOT countersink them just yet! Remove the plastic base plate on your router (usually black). Using some longer screws, screw the router base plate to the D-handle plate. Carefully drill a larger hole. I use a spade bit in the drill press with the assembly clamped to the drill press table. Don't try to match sizes, just bigger that your flush trim bit diameter.
I use a router table with the flush trim bit. Drop the screwed together assembly over the flush trim bit and router out a perfected sized, perfectly centered hole. Now disassemble the plates.
Install a rabbet bit in the router that meets or slightly exceeds in overhang, the rabbet in the router's original base plate. Route to the same depth as the original.
NOW countersink the router base mounting holes, paying strict attention to which side of the plate is against the router. Or you will be starting over. :-)
Install your handle on the D-plate. Use your factory collars with impunity.
See more in the book. Router Joinery Workshop. By yours truly.
Thank you, Colonel
Ellis Walentine, Host
>Your "official punster" status has been affirmed.
Bricofleur
>Thanks Carol for your input and precious advices,
I've started by reading your book (BTW - Congrats - I love it), then made the D-handle base, enjoyed it, and now you ended by refering to your book. The loop is tied.
Thanks again,
Sincerely,
Serge
>My pleasure.
You are welcome.
