OT sorta...Durabond and easy sand
Dave Tenney
>My wife has got me painting the house right now. When we bought the house (before we had kids) we painted everything flat, and now we're doing everything satin because it's washable. As I paint each room I've been fixing all the plaster cracks as I go...Chip everything out with an old screw driver and put on a couple coats of mud.
I've a some drywall work in the past (hung and finished two houses) and was wondering what you use Durabond for? It's the stuff in the brown bag. I've always used easy sand for taping and the premixed stuff for finishing.
I accidentally bought a bag of this stuff once for taping and couldn't tell any difference. It may have been harder when dry, but I never tried sanding it to tell.
Anyone know?
Thanks,
Dave
Re: OT sorta...Durabond and easy sand
Jason Roehl in Lafayette, IN
>Durabond is virtually impossible to sand. It could be used to float out large areas of a plaster wall to repair it, or fill in where chunks of plaster are missing, but it's not appropriate for drywall(sheetrock) in general. I guess you could kind of call Durabond a lay man's plaster. Stick with the EasySand for most things, or, if you're doing a lot of mudding, use a ready mix out of a bucket or box.
Jason
Slight hijack.... about those joints
Tim Greif - West of Chicago
>Sorry for the hijack. I was wathcing an episode of this old house the other night and they were doing drywall repair where a section of rock had been removed. The remaining drywall edge that they were attaching the new stuff to had a full thickness edge to butt up against (as opposed to the tapered edge).
They said it was a good idea to remove the paper at the edge of that piece and groove out a small depression to lay the tape into so there would not be a bulge. I was always told you should never remove the paper layer if at all possible since it weakens the joint. Is that advice old fashioned? which is the proper way? I always thought full thickness butt joints just had to be feathered out much further than the taper joints so the bulge was not evident.
With most of today's new construction using horizontal rock application, I gotta think there's still a bunch of butt joints being taped.
Re: Slight hijack.... about those joints
Justin Szeliga
>OK, they want you to cut a fairly precise trench in an extremely brittle & fragile material, & in the process remove the one thing that actually keeps the gypsum core from crumbling as you handle it, then to coat that exposed section with spackle, thereby pulling crumbs of the core into your tape seam causing bumps & steaks as you trowel it? Wow, makes tapering butt seams sound better than sex.
Peace
Justin
PS- I'd sand Durabond again (they say you only do that once...) before I'd try the method you described. Durabond for deep holes & cracks & fill ins that would take forever to dry if you used joint compound, and only when that can be coated again with EZSand or joint compound.
