Re: "astronauts are in more danger"
Alexander Grigoriev
>>--the foam insulation used on the large fuel tank. In the early days of the shuttle, it (the foam) stayed put during launch, but it was manufactured using CFCs.
CFC was withdrawn beginning in 1995.
STS-1, 1981: Crew reports white material streaming past windows during orbiter-external-tank flight. Crew estimated sizes from 1/4-inch to fist-sized. Post-landing report describes probable foam loss of unknown location, and 300 tiles needing outright replacement due to various causes.
STS-4, 1982: PAL ramp loss; 40 tiles require outright replacement.
STS-5, 1982: Continued high rate of tile loss.
STS-7, 1983: 50x30 cm Bipod ramp loss photographed, dozens of spot losses.[2]
STS-27, 1988: One large loss of uncertain origin, causing one total tile loss. Hundreds of small losses.
STS-32, 1990: Bipod ramp loss photographed; five spot losses up to 70 cm in diameter, plus tile damages.[3]
STS-50, 1992: Bipod ramp loss. 20x10x1 cm tile damage.[3]
STS-52, 1992: Portion of bipod ramp, jackpad lost. 290 total tile marks, 16 greater than an inch.
STS-62, 1994: Portion of bipod ramp lost.
