Light on a Router?
Light on a Router?
Light on a Router?
Sawman
>I was doing some plunge routing and I was in the dark trying to see my layout lines.
Anyone have any idea of retrofitting a small light on a router?
Re: Light on a Router?
Stealth Routing?
>In the Dark?
Hmmmm
How 'bout one of this FLIR headsets the troopies use to "Own the Night"? Other than that, I'd just turn on the shop lights.
Had a Crapsman router with a 12v auto bulb buried in the handle to shine into the bit bay. Bulbs broke from the vibration and the shield became opaque from abrasion and dust in short order.
Fred Davis
>I have a Stanley router I bought in 1965 with a side mounted light that shone brighter as the load increased.
Great idea , but the vibration would cut the bulb life short and replacements took a while to get from Stanley , so I took the light off.
After a rebuild years later , the router is still going strong.
One of the best features ever on a router was the depth adjusment gauge and I had four of them retrofitted to the models that replaced the first one.
FredD
Small LED light
>Relatively vibration resistant. I've seen them available in a variety of sizes. One nice looking set fit on a cap brim so you could have some relatively power lights that were hands free.
Sears brand router with light
Henry (Raleigh NC)
>I have to admit that the ONLY feature that I actually liked about my first router - the aforementioned Sears brand - was that light buried in the handle. I did not appreciate it fully until I moved on to (up to?) a PC 690. In a few limited situations I actually do miss that light.
Henry
GalenV in Iowa
>If you need a light to point back into the bit you might be able to adapt a bore light with the bent fibre optic end to focus back under the router.
Hoppes has a relatively cheap unit but not sure how long the battery life would last for your application.
I found a small LED "Finger light" that had a velcor strap and tried it on shaft of a hollowing tool to see inside a hollow form. Kinda worked.
Galen
Re: Light on a Router? *LINK*
Bricofleur
>Hi Sawman,
This is what I use (not watt I use!) to brighten layout lines when routing. I found these LED clamping lights at a local discount store. The left LED light head is mounted on a ball so it swivels, while the right one has a handy flexible neck, which is perfect to adapt to different router types and brands. They both can be mounted on any protruding parts of most routers. And better, I paid $1 each (plus tax of course!). I don't have to say that the batteries last for ever (or so). Save the picture on your computer and enlarge to see details with any photo management software (could be Paint).
Check more ideas on my website too.
Best,
Serge
Atelier du Bricoleur
Use the Norm Abram tip
North of the Border
>Norm attaches a small light with tow broom clips to the handle of the router. You can find the broom clips at hardware stores for about $2 a pack and a small LED flashlight at LV: http://tinyurl.com/d9gu68 special sale for just $4.95!. Connect the two broom clips with a bolt and nut or two and you're done.
Attach one clip to the handle and the other to the flashlight. You can even adjust the angle of the light. Norm was seen routing a couple of wooden signs using this shop-made light.
Happy routing!
Bricofleur
>Lee Valley carries a new flashlight holder with a magnet base. Could help if your router's body is made out of steel on which the magnet will stick. Could be usefull around the shop too! Hum!...I think I will consider to get one.
Best,
Serge
Lee Valley Flashlight Holder
