Cure for CA glue
Cure for CA glue
Cure for CA glue
Al Goldstein
>Got a panic call from my daughter yesterday. She was working on a project on her living room coffee table using super glue. She got up for a few seconds. Her young cat jumped up on the table and took the top of the super glue bottle in his mouth. Yes, super glue all over to top of the coffee table. Some pieces of paper are glued to its surface.
I gave her my tube of super glue release to see if it would work. The finish on the coffee table is lacquer. Is there any other solvent for super glue that will remove it with minimum damage to the lacquer surface?
I kind of doubt that she can avoid an expensive refinishing job - this kind of work is beyond my skill level.
TIA
Al
Re: Cure for CA glue
Tough one
Ellis Walentine, Host
>Al, I don't know of anything that will dissolve super glue without dissolving lacquer, too. That doesn't mean it doesn't exist, just that I have never heard of it. Let's see if anyone else knows of any magic solvents.
Sorry to hear about the incident.
i believe it was Bill Houghton that
Victor P
>said. Cats are God's way of saying we don't need nice things. :>)
Sorry to hear of your daughter's accident. No help here.
Victor waiting for the cool front and rain in Houston
Jesper, Denmark
Re: No help here either, but.......
Jesper, Denmark
>Be glad the cat did not get glued to the top!
Fred Davis
>Like Ellis ,
I seriously doubt a solvent would do anything but damage the Lacquer, Acetone being used to release the glue if it is still green would ruin the lacquer.
Since the possibility of a professional refinish looms , there is one way I know of to release adhesive quickly , having done it on floor tile and it is placing a piece of dry ice directly on the glue .
If it works , the release would be nearly instant, what it would do to the Lacquer is anybody's guess.
A caution about handling the dry ice is DO NOT TOUCH it with your fingers, use gloves and tongs, because it will burn your skin.
Dry ice is typically available from Ice Cream stores , delivery trucks and like that.
FredD
Tried
>some nitromethane CA debonder on a lacker finish that's scheduled to be removed anyway. Dissolved the lacquer nicely.
[Just so you know]
Before you try solvents,
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I would suggest that you take a well worn putty knife, to push at the edges, to see if it will just pop off. If your daughter kept that top waxed, it may just pop right off.
I use it for repairs on broken finished pieces. When it gets out on the finish, that is how I usually deal with it.
If that works, be sure to come back with a report for all to benefit from.
Collateral note
>As a turner, I use lots of CA for repairs.
To do so, I coat the surface with dewaxed shellac, then apply a coat of paste wax to the surrounding area as a resist/release coat. After applying the CA, any over-fill comes right off the wax. The wax and shellac are then removed and finishing proceeds as normal.
Thanks Guys
Al Goldstein
I was quoting someone else
Re: Cure for CA glue *LINK*
Keeth Miller
>One of my major hobby areas is Gemstone Faceting. As part of the process in Faceting Gemstones, we use Cyanoacrylate to temporarily mount the rough gemstone material to a dopp or mandrel so it can be held securely in a faceting machine.
After one side of the Gem is cut, it must be transferred to another dopp which is glued or wax mounted on the opposite side of the Gem before the first dopp is removed by using a CA remover. At that point, the first dopp is removed and the Gem,with the newly-exposed opposite side, is remounted in the faceting machine and faceted.
The CA remover contains nitromethane and is very effective in breaking down the CA.
Following is a link to one of better known sources of the CA remover. I tried to see if this remover would damage other surfaces which were painted or printed. That crude test showed that very little, if any, solubility was evident. Unfortunately, I don't think any of the test samples that I tried were lacquered.
The linked web site has a toll free number that you could call for advice about use on a lacquered surface. Perhaps they could even suggest an alternative approach since they manufacture CA and most likely have had a similar question before.
Take it slow with any tests and do them in inconspicuous places. Good Luck!
Keeth Miller
Central Virginia
Barbershopper, Faceter and sorta beginning wood worker
Super Glue Remover
