Sound insulating workshop walls
Hamish
>I am planning to set up a workshop in a room abutting the house. It is of cement block construction. I would like to soundproof the walls as much as is possible/feasible without spending millions, as we have some neighbours living close by.
Previously, in another room of our house, I had insulated the walls with 2 inches of Rockwool and observed that before I had covered it over with dry-lining, that the bare faced rockwool really soaked up any noise I made. Later, with the dry-lining in place, the room had more of an echo in it. Presumably because of the sound being reflected off the walls.
Bearing this in mind, I am wondering what the effect would be if I covered the insulated walls with peg board? Do you think this would be more efficient at reducing the annoying sounds originating from my machines than say covering the walls with MDF board?
It would be nice to hear what you have found to be effective?
Regards, Hamish.
Re: Sound insulating workshop walls
Dan Donaldson
>From your note, it looks like the objective is not to annoy the neighbors. That said, what you heard when you covered the walls before may not be important. You could very well hear an increase in echoes from inside without any increase in what your neighbors would hear. My workshop is insulated with fiberglass and drywalled. It is frame with siding on it. With the door closed, you can hear almost nothing outside of the building. I don't think that you will have any problem as long as the walls have insulation in them.
Fred Davis
>If your room remains dry all of the time (no condensation) I would glue Acoustical ceiling tile for the maximum amount of sound deadening possible on a budget.
Also there are some Celotex brand wall coverings available in 2'x8'x1/2" thick panels that are coverd with a Burlap type material , comes in different colors and it is a effective sound barrier, though not quite up to the level of Acoustical tile.
The Pegboard and the MDF are hard surface materials which will bounce sound all over the room and do little if any to deaden it.
FredD
mdclor
>Hamish,
The pegboard can be effective if you have unfaced insulation behind it. This will be effective within your shop. If you are able to put up a double stud wall with the two walls not touching, that is a two adjacent walls with a 1/2 inch space between the two walls and insulation in each, this will be even more effective for outside the shop.
HTH,
Merle
Jesper, Denmark
Jesper, Denmark
>The block wall plus Rockwool insulation covered with drywall wil make sure you don't bother the neighbors.
Any sound absorbing material to deaden the sound inside is likely to be a dust collector, as it will have to have some "fuzzy" surface to reduce the reflection of sound. IMNO not a nice thing in a workshop.
Al Stokka - Cambridge, Iowa
>Hamish,
If your only pbjective is to keep noise from reaching the neighbors, concrete block walls will be sufficient.
Al
Sam
>My shop is built with 2 X 4 walls, and stucco on the outside. On the inside I used R 15 fiberglass insulation, 1/2" soundboard, and 5/8" drywall. I also have neighbor concerns. With the doors closed it is very quiet. The addition of the soundboard helps alot. The soundboard is not expensive and can be purchased at Home Depot.
Good Luck, Sam
Jay St. Peter - Southern, MD
>Two different objectives you mentioned. Soundproofing, or keeping sounds from transmitting outside, is one thing. Acoustical treatment for the interior is different. If you choose to use pegboard instead of drywall so the interior is quieter, slightly more noise will make it through to the outside. Most likely with block walls and insulation, that won't be much of a problem. With that construction, I would concentrate soundproofing efforts on any wall shared with your house and not really worry about it otherwise.
In my basement I put a lot of effort into soundproofing. It was a cone of silence in the shop until the drywall went up. Then it echoed like crazy. But, the sound wasn't making it out. Once I got cabinets, lumber racks, and tools hanging on the wall the echo is pretty much gone.
Jay
Dan Donaldson
