O.T.: how to post links
John_in_Az
>Hello All,
I'm not very computer savvy, I guess old dogs-new tricks syndrome. Anyway, I've never learned how to post a link to another location. Can someone give a quick tutorial for posting links. I'm sure it's very easy. Thanks, John
Re: O.T.: how to post links
>Well, it depends on whether or not you are posting one or more. If you are posting one - go down to the optional link URL area and paste in the link there - and then add a title. If you are doing two or more, you can just copy and paste them in the text.
Such as: http://www.barbershop.org/.
You can also make live links in the text, but I don't like doing that - as I've seen some unusual locations.
Cut and paste
Ellis Walentine, Host
>You can paste a URL pretty easily. Open the page you want to post a link to and highlight the URL in the address bar of your browser. Then right click and choose Copy. Go to the place you want ), and put your cursor where you want to paste the link and hit CTRL-V or choose Paste from the Edit menu. Presto, the URL is pasted.
If you want to make this pasted URL show up as a clickable link, you need to issue the HTML command that does that. The format for the command is <a href="[URL]">[URL or alias for it]</a>.
EXAMPLE: <a href="http://www.woodcentral.com/forums">WoodCentral Forums</a> creates this link to our forum splash page: WoodCentral Forums.
To paste a URL as a working link in one of our messageboard posts, copy the URL you want to link, put your cursor in the Optional Link URL box under the message textarea (where you type your message) and hit CTRL-V or Edit > Paste. The URL will show up at the bottom of your message as hypertext that will be clickable. If you want something besides the actual URL to show up, type an Optional Link Title for your link in the box under the Optional Link URL box.
Jim Dillon
>Hi John,
If you are using Windows Internet Explorer 7, I have found it convenient, while browsing WC, to open a new tab (click the little box next to the WC tab), then go to the web site you wish to create a link to, highlight the URL address at the top of your screen, and copy (right-click, copy), then reopen your WC window and paste (Ctrl-V) your URL link where you want it. This takes longer to explain than to actually do. I know nothing about Macs, or otherWindows web browsers, but hopefully - together with the other posts - this will help.
Jim
IE7 with tabs
>Same with Firefox.
Also, you can open two browsers side by side and drag/drop a URL directly into a message while composing. (easier with dual monitors)
Also, you can copy/paste a URL into Notepad or something then copy into your message later. I do this when composing a message with multiple links.
Re: IE7 with tabs
Jim Dillon
>Hi John,
Good to know. Sometimes I am tempted to try another browser as I always hear good things about Firefox and Mozella. Maybe someday... ;-).
Jim
Keeth Miller
>Wow! It appears that there is at least one other Barbershopper on the Wood Central List-Serve. Your example link, www.Barbershop.org, sure jumped out at me!
In the past, I considered asking if there were any other Barbershoppers on board and didn't do so. I suspect that you might be a Barbershopper.
Barbershop Singing becomes a way of life for many and a great family activity. Even though our numbers are continually declining, there are still about 28,000 of us around. As I recall, we peaked several years ago at around 38,000 plus.
I am a member of The Virginians Barbershop Chapter in Richmond, VA and have been deeply involved in Barbershopping since 1973.
My apology if this is an out of bounds suggestion; however, it would be very interesting to know if others of you are, or have been, Barbershop Singers.
Anybody else out there?
Where do you, or did you, sing?
What voice part?
Keeth Miller
Lead
