A55 Smoothing Plane
OTcomputer driving me crazy
jim runchey
>My Toshiba laptop is really acting up. We're in Florida and the condo here has wireless internet. It takes forever, when I click on Firefox, to come in. I didn't think it was going to make it this morning. I have AVG so I don't think it's a virus. When I go on ctrl-alt-del it shows about 55 items. Should a lot of these be deleted? If so what is the procedure? Any thoughts will be greatly appreciated.
Re: OTcomputer driving me crazy
Dan Donaldson
>If it was working OK before, it might just be the hotel connection. As to the 55 items, it is possible that some of them could be deleted or turned off, but unless you know exactly what they all are, you should not mess with them. You can bork your whole system if you delete something you shouldn't.
Ed Beck
>By Ctrl-Alt-Del you're opening up the System Manager, right?
Don't stop any of these unless you know for sure what it is and that you don't need it now. If one of these is running amok you can sort by Memory Usage or CPU Usage to see what's eating you up.
If you do stop one doing a re-boot will get it restarted, and unless you had really bad luck you should be OK.
However it's most likely that it's the hotel connection that's causing problems with your connection. Especially if there's a lot of people on the internet using the same access point.
You down there for Spring Training?
