REAL MILK PAINT
OT - Washing machine woes
>I have a Kenmore Elite of indeterminate age. I am presuming it is less than 10 years.
Upon occasion it will not spin. The agitator agitates properly in both the wash and rinse cycle. Sometimes it won't spin after the wash cycle. Sometimes it won't spin after the rinse cycle.
I was given a diagnosis over the telephone. The man said my timer has "flat spots" and needed replacing. By timer he meant the main timer/cycle mechanism.
I'm not doubting him. It does sound plausible. However, if I'm going to pay 1/4 of the price of a new washing machine for a part (and repair), I want to get a second diagnosis. I then have to make the decision as to if I would rather repair it or replace it.
Does anyone have any thoughts or sage words of wisdom?
TIA
Re: OT - Washing machine woes
Jim Shaver - Oakville, Ont
>When it spins does it make a Whirrrr'ing sound or click click?
Jim,
Curly Smith
>I'd say that's the wrong diagnosis. If your timer had a "flat spot" it would hang at the same point, not sometimes on the wash and sometimes on the rinse. My diagnosis is that your lid sensor is faulty or loose, the spin cycle has a "lock-out" if the lid is open. The next time it "hangs" try opening and closing the lid.
>Curly - usually when I leave the lid up, it just stops at that place in the cycle.
The problem is that it doesn't spin and continues on with the cycle. After the wash part, it drains and then fills and agitates for the rinse cycle. It then drains again at the end of the rinse cycle. The only thing it isn't doing is spinning to wring out the excess water.
You might see if your local library's got a book
>I picked up a Time/Life book on "Major Appliances" at a garage sale that's been surprisingly helpful in keeping our older Maytag washer and dryer running (and, from what I hear about the new ones, I think I may want to keep them running forever). The trouble-shooting list on that is too long to repeat here; you might see if the Time/Life book or another good one's available.
E-mail me if your library strikes out.
Lee Schierer - McKean, PA
>To spin, there is a solenoid that pulls on a shift lever in the transmission. As I recall this shift lever also has a spring that holds it in the normal position and the spring is the weak link in the design. Check to see if you have a spring hanging under the washer from teh transmission. It may be laying on the floor under the washer.
Lee
Re: You might see if your local library's got a bo
>I don't have one at my library (the wonders of a computer accessible library catalog). There are a number of books in the associated library catalogs from various Time-Life series including some on major appliances as well as appliance repair. If you have a specific title, I can request it via inter-library loan.
http://gapines.org/opac/en-US/skin/default/xml/rresult.xml?rt=keyword&tp=keyword&t=time%2Flife%20appliance&l=96&d=0&f=&av=
David Anderson PacNW)
>Try replacing the belt. I had a maytag that did the same thing
Just for laughs & giggles . . .
steve mackay
>Look on the floor, under the machine and see if theres any rubber or white plastic bits or "shavings". In eleven years the only thing that puts our machine in a "mood" is the linkage between the trans and the drum. Two rubber gromet look'n things and a hard (talc + PVC) white plastic linkage piece. I don't know, worth a look-see. Only twenty bucks.
Fred Davis
>I don't know it they still do , but WhirlPool made Kenmore for years , identical except fot name tag .
Maybe your library has a Whirlpool manual
I have a old one that says Kenmore /Whirlpool on the front.
FredD
Bill Turpin in WNC mountains
>Do a Google search, "How to fix my Kenmure washer?" There are some wonderful sites on appliance repair. Try Kenmore site also. GE washers have a clear plastic tube from tub bottom up to top where the level control is. Every year a clear jelly will stop up this tube...clean with a moist Q-tip. Kenmore used to have a secret support to remove to change the belt. You can cause hundreds of $ damage being un-informed. E-mail me for more info if you decide to replace the belt. Ebay has discounters that sell new, factory original parts in sealed factory bags.
Re: OT - Washing machine woes *LINK*
Bob Entwisle in NJ
>Hi JL,
I fix all that stuff myself, they are not very complicated machines, sort of like a tablesaw with a transmission, water, a timer, and a couple other features....etc.:)
I've gotten Ton�s of useful information on the web for troubleshooting and repairing appliances. (even just how to disassemble them). One site that has helped a lot with diagrams etc. is http://www.repairclinic.com/Home.aspx
So depending on how you feel about appliance repairs, if it were me, I'd start taking it apart and researching it on the web until I either figure out the problem and fix it, or find that the parts cost is more than It's worth to me.
That said, having recently looked at new washing machines on a whim with my wife, It seems that the 4-500 bucks that I think a washing machine is worth, is now up to 1000-1500, for a washing machine my wife 'likes'. So the value of the old machine has increased by about 50 to 100% in my eyes. I imagine sooner or later it will need to be replaced, but not this year....
Good luck
Bob in NJ
Dan Mitchell
>As an aside, Kenmore appliances are/have been made by literally scores of companies, here's a link that tells you who made any given example based on the 1st 3 digits of the model number.
I agree with Bob, appliances are in the main pretty easy to repair, and you can save a bundle doing so yourself. I don't think I've ever paid to have one fixed. Much more convenient this way as well; no waiting around for the white van. A good DIY book from the library or local book store can be a great way to get started, assuming you have a decent basic set of tools.
Dan
http://www.appliance411.com/parts/sears.shtml
Re: OT - Wig Wags *LINK*
pecker
>I have an older Kenmore that would sometimes not go into the spin cycle.
It turned out to be an intermittent solenoid coil...I could tap on it sometimes to get it to engage.
The repair guys call it a wig-wag. It wasn't that difficult to DIY, but you should try to verify it's really the cause of failure. You can get a little more info about them at the link.
http://www.pcappliancerepair.com/washer-whpl.shtml
