We value your privacy.
>I am in the middle of remodeling my kitchen and family room. I would like to deaden the noise between these rooms and my childrens' rooms above (I have hardwood floors above and can hear quite a bit of the noise). As part of the remodel I have removed the ceiling. Since the ceiling is open I was thinking about stuffing the area between joists with insulation.
Will this have much of an effect?
Is there something else I should also be looking at.
>Give some thought to bunny slippers and nerf balls. And Carpet upstairs.
There are at least two types of noise here that might be factors. Impact noise is transmitted by the structural material. This is things like heels hitting the floor or golf balls being bounced. Another type of house is airborne noise like speech or music. This vibrates the floor and somewhat indirectly passes through the material.
The insulation MIGHT help with the airborne type. If you can find the denser sound absorbing type it might be better. I doubt this will help much with the impact type.
Another thing you could do is use sound isolation strips on the bottom of the joists. These are sheet metal strips that are sort of "Z" shaped. You screw one edge of the strips to the joists and the sheetrock to the strips. They support the ceiling on a sort of spring action. This could reduce the noise more than the insulation, because it limits both types of noise. (You could do both).
You could also install a second set of ceiling joists, parallel to but not touching the first set. They would be slightly below the original set (1/2" or even less). Then attach the ceiling to them.
Good heavy carpet upstairs would probably be even more effective and maybe cheaper.
>This is WOODcentral, Barry--he said he has hardwood floors upstairs! It's sacrilege to suggest laying carpet over hardwood! ;^)
(Just funnin' ya, though it pains me every time I have to refinish a hardwood floor that had been covered with carpet...and tack strip...and pad staples...and holes for telephone or cable...)
>I agree with Barry. Also, thicker dry wall is a good sound deadener if it is isolated from the joists, so you could use thicker dry wall or use two layers that are isolated from each other by the z-strips or with an elastic sealer. If not isolated from the joists, it acts like a drum head or a sound board. It all depends on how crazy you want to get.
>Barry, I did some research on the Net too and found a suggestion of combing both sides. But my own opinion is to remove the velcro with a citric acid solution if glued on, or if sewed cut the string and buy some new material at a local sewing/linen supply store.
I agree with Barry about using the "Z" strips/clips. And then again, think about the cost of putting in the insulation or the clips. You have already the cost of the new drywall, or whatever material you are going to install...like ceiling tiles maybe, and the paint, Consider the cost of the insulation to the cost of buying many clips and installing them as specified. I firmly believe the clips are the answer. And I was in construction for 35yrs before retirement so I do know a little about this work. Also, was a Building Inspector in
>I did insulation and resilient channel on the ceiling of my shop. It helps some, but the banging on the floor is coming through. My experience is that it helps more that sounds from below don't make it up. But, banging on the floor above still makes it down.
>During years of General contracting in California , this was a subject that came up constantly and the only really good solution to sound transfer was planning for it in the design stage.
That being said , in addition to what has be recommended or suggested , you can help the problem quite a bit with Acoustical ceiling tile preferably with no physical connection to the drywall , but even attached directly , it will help to inhibit noise transfer.
Lastly , look in your yellow pages for a Acoustical Engineer or a firm dealing with sound deadening, very in expensive to find out the best way in your particular situation.
>There is a product called QuietRock that claims to be much better & cost competitive with hat channel sound proofing. A google search will find the site.
>I checked with a local drywall supply house in the Twin Cities and a 4X10X5/8 sheet of QuietRock sells for $110 a sheet. If you go that route, I hope you have a good job like a lawyer for an airline to be able to pay for it. Cheers
