Paint thinner recycler
Dave LaPine
>In an old wood working magazine I recall seeing a mineral spirits/paint thinner recycler made from a section of PVC tube that is mounted to the wall. It would let the solids settle out at the bottom and allow you to retrieve the thinner higher up the tube for cleaning brushes. I googled it and didn't really see what I was after. Probably wasn't wording it right. Any ideas?
Re: Paint thinner recycler
>I just put the paint thinner in a plastic milk jug (although, if you have a swimming pool or spa, the heavier jugs the chlorine come in would be better - with barometric changes, the lighter milk jugs can kind of pooch in, like a little kid making funny faces) and let it sit for a few days. The solids settle out, and I can then gently decant the used thinner for brush cleaning. I return the re-used thinner to the jug again and repeat the settling process. At first, I don't get enough thinner out of this for thorough brush cleaning, so my final rinse is with fresh thinner, but after about the second time, I get enough that I can often use the recycled thinner for the full cleaning. After a while, the thinner carries enough dissolved compounds (that don't settle out) that I need some fresh thinner for the final rinse. Over time, this leads to a full jug of very used up thinner, which I then cap and take to our local hazardous waste disposal site. I wind up starting a fresh jug of used thinner (kind of an oxymoron, but I don't know how else to say it) even before the existing jug is all "used up."
I'm a moderate - that is, not constant - remodeler, and it can take a year or even two for a jug to reach the point of hazmat disposal.
If I were using oil-based paints or finishes more frequently, I'd probably have two jugs going in rotation, to give time for the solids to settle.
The love of my life also points out that, over time, the recycled thinner will get more than a little stinky...but the savings, to my wallet and the environment, smell sweet; I just don't bring it in the house.
Wandering off topic: For some years now, I've cleaned the paint thinner out of the brush with non-gritty mechanic's soap, rubbing it in and then washing with water. This leaves a clean, soft brush without noticeable oily residue. The citrus-scented (and maybe citrus-based) soaps are especially nice.
>I use quart glass jars. When the solids settle, I decant into a bigger container. I've got a "light" jar and a "dark" jar and light and dark larger containers. When the glass jars get too full of solids, I remove the lids and let them dry (outside) or put them on the burn pile.
pooch in ?!
Charles Yawn
>Now that is funny. But you know what? I realize exactly what you are talking about! Thanks for the snicker. Charles
Yonak
>I'm the same as the others except I use a rotation of clean paint cans. When one is filled up, I put it on the shelf and start filling another. By the time the second one is filled the first is settled out and ready for pouring off and refilling.
Technical term, of course
>I always picture my sons closing their mouths, opening their jaws, and sucking in their cheeks to get the look most of the milk jugs I've used for this purpose take on after a while.
