Cleaning prior to refinishing
Ralph Lipeles
>My wife wants me to refinish our family room card table. It has a 34" square top with a walnut/maple checkerboard built in and 4 circular cutouts for cork coasters. The remainder of the frame is pine, dyed walnut. There are a bunch of small chips out of the finish. My concern is that for years she has been using a spray when dusting that contains silicones. After I strip the table top I am sure that the silicones will remain and have a disasterous effect on the final finish. Any ideas on a way to clean the top that will remove the silicones??
Thanks,
Ralph
Re: Cleaning prior to refinishing
Howard Acheson
>Here's the process. First, use a chemical stripper containing methylene chloride to remove all the finish. Do the process twice. Now wipe down the surface with lacquer thinner using lots of fresh clean paper towels. Even as clean as this will get it, there will still be silicone contamination in the wood. YOu need to create a barrier coat between it and any finish you now apply. You can not apply a stain at this point.
Unless you have spray equipment, buy a couple of cans of Zinsser Spray Can shellac. Spray an even coat on, let it dry and then spray a second coat. Do not sand after either coat. After at least 24 hours, you can use a gel wiping stain to color the wood. Do not try to use a regular oil based stain. You will probably have to mask off the inlay game squares area. Let the stain dry. Apply your first coat of clear finish, let it dry 24 hours and lightly sand it with 320 paper being sure not to sand through or you will have destroyed the barrier coat. Then apply 2-3 more coats of your clear coat.
Al Stokka - Cambridge, Iowa
>Ralph,
Compliments of Michael Dresdner mid-April 2007:
"The solvent for silicone oil is mineral spirits. Scrub contaminated raw wood with liberal amounts of mineral spirits and sop up as much as possible (don't just spread it around.) Follow that with a scrub of liberal amounts of warm water laced with household ammonia, which is a surfactant for silicone oil. Again, mop up as much as possible. This one-two punch will remove the lion's share of the silicone oil."
Al
Ed Mulligan, Cape Cod
>Ralph -
In my one foray into refinishing a silicon-contaminated piece, there was silicone down in cracks that defied efforts to remove it but which bled out onto the surface when stain was applied, with characteristic fish eyes. Many coats of sprayed shellac had zero effect. I took it to a pro refinisher who was able to overcome the difficulty. Just an fyi in case you too encounter a problem.
That's correct, but let me take it a step further
Michael Dresdner
>The washes Al described are right, but you must really scrub and sop, and repeat until the solvent wipe clear. The surfactant you will probably only need to do once. All that must be done prior to sanding.
After staining, the first coat of finish, as Howard suggested, should be dewaxed shellac, which you can buy as Zinsser SealCoat or in aerosol cans as Zinsser Shellac, but not as liquid cans of shellac.
However, you may not need to go this far. Silicone creates surface tension issues, which are significant for both waterbased and lacquer finishes, but are far less of a concern for oil based finishes, and almost no concern at all for wipe on oil based finishes, such as gel urethanes or Danish oils.
RICHARD MELTON
>I SPENT 47 YEARS WORKING IN THE PAINT INDUSTRY FORMULATING CHEMICAL COATINGS. SILICONE IS ONE OF THE MOST INSIDIOUS CHEMICALS EVER ADDED TO PAINT. HOW WOULD YOU LIKE TO HAVE A WHOLE PRODUCTION LINE OF AUTOMOBILE BODIES THAT ARE COVERED WITH FISHEYES? SILICONE ALTERS THE SURFACE TENSION OF THE COATING CAUSING IT TO FLOW OUT TO A VERY SMOOTH SURFACE. A MINUTE AMOUNT OF SILICONE ON THE SURFACE CAUSES IT TO BE VERY SLICK AND MAR RESISTANT.
REFINISHING A SURFACE THAT HAS BEEN TREATED WITH SILICONE CAN BE VERY DIFFICULT. AS WE WASH THE SURFACE WITH SOLVENT OR SOAP AND WATER OR WHATEVER, THE SMALLER THE AMOUNT OF SILICONE THE WORSE THE PROBLEM CAN BECOME. ENTER FISHEYES. THERE ARE SILICONES THAT ARE RECOATABLE. PROFESSIONAL COATINGS SUPPLIERS HAVE SILICONE SOLUTIONS THAT CAN BE ADDED TO THE PAINT, LACQUER, OR VARNISH IN VERY, VERY SMALL QUANTITIES TO PREVENT THE FORMATION OF FISHEYES IN THE TOP COAT.
