Semi OT: Metal Garage Kits
David Hay @ Denver
>Does anyone have experience with metal garage kits such as those offered by Absolute Steel? LOML and I are exploring options for building a larger building for my shop and this seems like an attractive option.
Thanks!
David
Re: Semi OT: Metal Garage Kits
Victor Parisian
>Metal building industry has a bad reputation for not disclosing all costs on the front side. "Oh, you never mentioned that you wanted a door (window, slab,...)with that". The price advertised in surely for just an absolute bare-bones kit. Think loafing shed.
Make sure any contract is very clear on what you will and will not get. And go over the contract with someone qualified to point out shortcomings. I have heard serious horror stories about everything form quality of steel (If you can cut the siding with a box cutter it may be a wee bit thin.), quality of the concrete (think gravel with some sand and a little bit of cement). Make sure you have thought of every detail from moisture barriers to roof vents things that would seem obvious from an outsider.
Victor - rant over
Victor
Dick Coers
>I know one guy that built one. I didn't get a lot of details, but he did complain about trying to insulate it. He basically ended up putting a building inside a building trying to make it energy efficient. He lost it in a fire, built a traditional wood frame structure the second time.
Metal is never good when cold and humidity get together. Turn on the furnace and you will get water dripping off the steel.
Kirk (KC) Constable
>I'm finishing up a lower-end 18x21 building from Mueller Inc. (www.muellerinc.com). Part of the 'problem' with metal buildings like this is that people are putting them together themselves... and there's a definite learning curve. Unfortunately, the 'lessons' usually show. Other than a couple of rookie errors, my building looks just like the higher end (heavier steel frame) buildings.
I've got no real complaints about the quality of material, and it went together well. Insulation is a spendy option, as are extra doors and/or windows.
David Yoho
>David, your option looks like a good place to start. For a comparison and a look at another great company's products check out this link to National Barn.
Probably costs more but I would use their guys to assemble it and then finish the inside myself. They will do as much or as little in the setup process as you want.
I like the idea of the wood framing for the inside and the metal shell for the exterior. You have the choice of having the framing around a poured slab or anchored on top of it. These buildings can be easily insulated before finishing the interior whatever way you decide. Personally, I wouldn't want a shop building with metal walls on the interior.
David
