Wood rack to hang from floor joist
David Hammelef
>Been a long time. Hope everyone is doing well.
I have a bunch of lumbar on shelves in the old part of my shop. Trying to clean up but the new shop does not have walls yet and may not for a few years (basement shop poured concrete walls). But I would like to move all my lumber into it. So does anyone know of a good lumbar rack that I could hang from the joist (prefer one that could get modified to a wall rack when I have walls in a few years).
So any suggestions?
Re: Wood rack to hang from floor joist
>What's wrong with placing shelves on poured concrete walls? You can easily attach the shelves now and remove them if you decide to finish the walls later.
I've seen a number of methods. Invariably they have supports coming down from the joists and cross pieces between the supports. One interesting method I saw in the shop of a friend had 2 x 6s coming down from the joist with iron pipe running from 2 x 6 to 2 x 6. He had PVC sleeves over the pipe between the 2 x 6s. Obviously you can't get more than a couple of layers of boards.
I wouldn't hang it from the joists
Ellis Walentine, Host
>... unless the verticals go all the way to the floor. Floor joists are designed to support a certain uniformly distributed load. Depending on how much lumber we're talking about, the dead weight could stress the floor above if it is supported only by the floor. I'd consider a floor-to-ceiling structure, which you can then anchor to the joists above to keep it from racking.
Mr. Cheap-o . . .
steve mackay
>has a bunch of steel bed rails hang'n from the joists with lag bolts. One rail 'bout every four feet.
Re: I wouldn't hang it from the joists
Ed Mulligan, Cape Cod
>This isn�t pretty but it�s cheap, quick to make and works well.
The uprights are a sandwich of three 2x4 wall studs glued and screwed together. Before assembly the central stud is cut to form 3 or 4 mortises to receive 2x4 shelf support arms. The mortise upper and lower faces are cut at a 3 or 4 degree angle so the shelf supports have a slight up-angle. Shelf supports are 18� long with 14 �� exposed.
Position the uprights on the concrete floor and bolt them to the floor joists. The uprights don�t have to contact the wall. The concrete floor will probably not be level and so the shelf supports will slightly out of alignment horizontally. To correct this on my shelf I just tacked shims on the low supports.
My shelves have uprights every second joist or 32�. Four uprights span 8� and can accept 10� lengths of lumber. Each shelf support can support many hundreds of pounds of weight. Each 8� shelf with 3 supports can support 1,000 pounds plus. If there are 4 shelves on a set of 4 uprights they can hold several tons.
Re: I wouldn't either. :-)
Ray Carson, New jersey
>Sounds like a good idea. Floor support is better.
Ray
Look for bankruptcies
Pat Evans
>Years ago I paid $50 for several sections of storage shelves from a warehouse that was changing out their storage system. These shelves were made from metal lumber with wood slats. I dismantled the shelves and used the material for all sorts of storage. My first two work benches were made from metal lumber and plywood. Using the same technique that Ed uses, but with metal lumber works great for wood storage.
That said, with the economy in the shape it's in and bankruptcies everywhere, there might be some opportunities to acquire shelving materials on the cheap.
Frank Mutchler
>I use four 4"x4"x10' posts from concrete floor to a roof joist. The joist simply provides stability and bears no weight. Pieces of iron pipe from the borg are set into the posts at about 5 deg up angle to support the lumber.
Fred Davis
>Ellis ,
is exactly right about overloading a structrual design system( floor joists in this case).
His concern about dead weight versus live loads can be thought of this way.
In any support system , a steady strain , like dead weight ,is the worse sort of strain and is accumulative and needs to be considered in a conservative way , which means, what is the heaviest load this design could safely carry over it's structural life.
FredD
FredD
Randy Johnson Connersville IN
>While the posts advising against hanging from the ceiling all seem logical, I keep thinking of chicken houses.
For several years some friends of mine were in the egg production business. They had 32,000 hens in two buildings. I�m guessing that each building was at least fifty feet wide. The trusses were on four foot centers and were none too beefy. The horizontal section of each truss was no more than 2X8 and I really think they were 2X6. The only support was on the outside walls. To me, even with trusses, that seems like quite a distance with no support. But that isn�t all. All of the weight of the chickens, cages, water delivery, and food hung from those trusses. Every time I had to go into the attic for some maintenance chore I crossed my fingers and hoped everything would hold. There was definitely more flex than I ever experienced anywhere else.
When discussing whether or not it is advisable to store lumber from a rack suspended from floor joists I would think that type and quantity of the lumber would play an important part in the decision.(oak vs poplar) You wouldn�t want several tons hanging from one location but if everything is distributed evenly and the weight kept within reasonable limits I can�t see it being a problem. I would try to mount the system as close to an outside wall as possible.
Dennis Yoder
>David, you might want to check with your local Circut City for warehouse racks that they are liquidation. Dennis Y
BobP
>Dave,
As already suggested I would not afix a wood rack to floor joists if you expected to have load of more than, say, 10 lbs per joist. Perhaps suitable for trim molding and such.
I have never liked fastening things to my poured concrete walls so I made my wood rack "almost" free standing. Its supports are firmly resting on the basement floor. The support at the top of the rack is primarily to keep the rack from tipping. I have included some photos of my present rack (simple, primative, but it works well for me). In the photos you will see that this rack is supported at the top by a 2X4 that is screwed to the wall. This is a 2X4 stud wall infront of the poured concrete basement wall. In a previous version of this rack that 2X4 was screwed to the exposed floor joist instead of the wall. The vertical rails and the shelf brackets were purchased at Home Depot but are available from other sources (WW catalogs?).
You cannot see the base of the rack but those vertical 2X4 go all the way to the floor and are sandwitched between two other 2X4 (on the floor) that run left-to-right. There are also spacers that keep the bottom kicked out from the wall. The vertical support 2X4 are not plumb but instead lean back a bit at the top (a small effort to keep most of the load down towards the floor and not trying to pull my wall over).
BobP
(other pics to follow)
BobP
>The support at the top is a 2X4. Here it is fastened to wall, previous rack installation this 2X4 ran across several floor joist and was screwed to each.
3rd photo
BobP
>This pic shows the type of brackets I used. They come in a wide range of sizes and the vertical rails allow for great adjustability.
