REAL MILK PAINT
OT: low flow toilets
Dan Mitchell
>I need to replace a couple aging toilets & should probably get something that uses less water. I see though that many of these are pretty pricey, $500-ish per unit. Worst case scenario, you spend that much, only to get a toilet that requires 2 flushes (and therefore, an equal amount of water) to get the job done. Anyone have any advice on makes/models of these, or know of a good review of various examples?
TIA
Dan
Re: OT: low flow toilets
Howard Norman
>You don't have to pay $500 for a good toilet these days. All if the new toilets are low water usage toilets as far as I know. I bought the last one about 2 1/2 to three years ago at Home Depot. I don't recall the brand and it is upstairs so not readily available to look at at the moment. The guy in the plumbing department the day I bought it was a retired plumber and I asked what was a decent flushing toilet and he suggested this one. I think that I paid in the neighborhood of $200.
Toto's
Jim Shaver - Oakville, Ont
>Hi Dan,
I just replaced three toilets in my home with Toto's, they have a 3 liter or 6 liter flush, depending on the need. Love them!
My local region also gave a rebate on installing them, $ 75 per unit.
Take care,
Jim
Thomas S Stockton
>In our old house we had a lower end Kohler low flow that worked well, The trick the plumber told us was with poop to hold the lever down during the whole flush. Never had a problem.
Tom
Re: OT: low flow toilets *LINK*
mdclor
>Dan,
We went with a Toto and are very happy with it. Check out this site for more info. They can be sorted by price, ascending or descending.
HTH,
Merle
http://www.toiletsthatwork.com/
steve mackay
>Weeeeeeeeeeeeeeeell . . . a lot of ARMY bases are re-modeling. If you're near one where you can "slink" around there are old ones (read : non-low-flow ) laying around in pretty good shape. But you didn't hear it from me !
Kohler integrity series
>Home Depot, $350 when we bought it two or so years ago.
We bought it because LOML wanted a Victorian looking toilet to fit our old house, but I'm ready to get a second one because it works so well.
It's not listed as a dual flush, but if you hit the handle and let up, the flapper falls over when the tank's only about half empty - and that's enough, 90% of the time. Maybe more.
I don't know what engineering marvels they worked, but it's a fantastic toilet.
Another vote for Toto and a tip...
doug f, san clemente, ca
>We replaced all of our toilets with Totos when we remodeled this winter. They work great and through a very knowledgeable plumber I found out the reason.
Toto (and several other manufactures now) use a 3" flush valve in their low flow toilets as opposed to the 2-2 1/2" ones on standard toilets. The difference is small in inches but huge in flow volume.
You should be able to get away with $200-$300 per unit, but check the specs carefully before you buy.
Doug
Toto
>Just put in a Toto one-piece a couple of weeks ago. My wife did a lot of research and that came out on top. (that's what she wanted for her birthday!) Saves on water and NEVER needs that second flush. Quick to refill as well.
$425 and well worth it. I could have saved a little ordering from another dealer or on line, but I found one in stock locally, picked it up, and had it installed the same day.
The plumber who installed it said he'd be back next week to install the others! He said most of the people who get one of these end up switching out their other bathrooms as well. I've got another one on order and I'm thinking about a third.
Variable flush
>I've never seen it described as that, but that's the best way I can describe it to fellow woodworkers used to variable-speed tools ;)
We have the same Kohler toilet and it's superb. Never had to double flush. Either press the lever down quickly, perhaps halfway, or hold it down longer if required. Seems to work like a variable-flush feature.
I think the reason they are water savers is that they only use alot of water when necessary. When alot of water isn't necessary, it only uses a little, but it uses as much water as a regular toilet (perhaps more) only when necessary. So a double flush isn't ever needed.
Happy Woodworking!
Jay Lombardo
>Another vote for Toto. put one in 3 1/2 years ago and it works great. they are available at plumbing supply houses.
AS Cadet 3
Dave Tenney
>I replaced both the toilets in our house with these a few months back. They are 1.6 GPF and could probably suck down a basketball. I've been real happy with them and they were only about $125 a piece. I like the elongated bowl too.
Dave
Toto too???
Dan Mitchell
>Sounds like we have a consensus, I LOVE that! Makes deciding so much easier.
And my wife will approve, what with The Wizard of Oz being one of her favorite films.
The local water concern had a rebate on low flows in 2008, $100 each I think, which ain't bad. I've emailed them to see if the deal is still in effect.
Thanks for all the helpful input.
Dan
Jesper, Denmark
Re: Toto's????
Jesper, Denmark
>Hey Jim,
Was that a Canadianized version or the full Japanese TOTO with fume ventilation, white noise generator (so the women do not think their expurgations can be heard), seat heat (should be nice in the chilly north) and multiple spinkler systems depending on the anatomy of the user?
Every time I visit Japan, the hotel TOTO's have aquired new functions - I suspect there is a Microsoft connection there somewhere, as the pictograms explaining the functions on the control panel could well have come from Redmond.
Re: Toto too???
>I suppose it goes without saying, Get an elongated bowl. More comfortable. Maybe all Toto's have a long bowl?
Our Kohler works very well
Lee Schierer - McKean, PA
>We've been very satisfied with our Kohler Wellworth series. They have a dual flush system that has never failed to get the job done.
Lee
Andy Lincoln,in Dearborn,MI
>Dan,
My best friend is a plumber and per his recommendation we have installed 6(yep 6 between 4 houses) Mansfield Summit toilet the older model was known as the Mansfield Maverick.They all have a 3"flush valve with a 1.6/gpf,low water consumption.They work fantastic.They are available at plumbing supply houses and only cost $130 !!!!The Totos are great toilets but no-one I know has been disappointed with the Mansfield.My friend the plumber averages 4 of these a week and the only call back is to install another.
Andy
Didn't Dorothy's Dog Have A Couple
>Good Afternoon Jim,
Glinda quantified the number by "Toto's Two!" just before they returned to Kansas. :<)
George
Curtis Gray
>Can't go wrong with the Toto Drake. I have 4 of them, and after 4 years, you can just about throw away the plunger.
Chris Friesen
>I've got an American Standard FloWise. Uses 1.2 Gal/flush. Haven't ever plugged it.
It uses the same flush mechanism as their Champion series, and there have been reports of problems with the valve wearing out but I haven't had any issues myself.
No experience with any of the others.
(Toto Two)Two
David Hammelef
>Just a fourth voice to recommend a Toto
