Re: Cutting narrow slices
Ellis Walentine, Host
>When I see questions like this, my editorial instinct (and liability instinct) is to pass, because I don't use a blade guard or splitter for this operation, and a lot of people think this is absolute heresy. I'm just telling you what works for me, and I wouldn't pass it along if I didn't think it was safe. That said, my disclaimer is that nothing is completely safe, and it's up to you to decide whether you want to try this or not. Your safety is your business.
To me, this is a straightforward ripping operation, no jigs or bells or whistles. The secret is in the push stick, or push block might be a better word for it. The style you want to use is shaped like a boot, with a tall handle that keeps your hand far from the blade.
Raise the blade about 1/4" or less above the thickness of the board, set the fence 1/4" from the blade, and rip your board normally. (I wouldn't try this with a board that is narrower that several inches wide to begin with, and I wouldn't recommend ripping strips thinner than 1/4" or so.) When you get down to the last foot or so of your rip, hook the push block onto the back of the strip, keeping the side of the push block firmly against the fence. Apply forward and downward pressure on the strip of wood by pushing on the handle of the push block. Do not attempt to hold the main part of the board with your left hand, just let the push block do the work, and follow through until you've pushed it past the blade. On the first cut, the blade will cut a kerf into the bottom edge of your push block. That's normal; these things are meant to be sacrificed.
If you are concerned about keeping the push block tight and flat against the fence, you can make a push stick that straddles the fence. If you have a riving knife on your saw, you can use it, but that means you need a push stick/block that is less than 1/4" thick to clear the riving knife. To me that's dicier than the straightforward method I described.
There is a push device called a Grrripper that has rubber pads to hold the piece down on the table. I've heard people recommend this tool for ripping thin strips, but I can't speak from experience.
