Glue in drawer bottoms??
Ralph Lipeles
>I've always been taught that drawer bottoms should just slide in the 2 dados on the sides, into the dado in the front and be tacked to the back. However, that makes sense when the sides are hardwood and the base is plywood or or solid wood with grain perpendicular to the sides. I'm making some drawers for a workshop bench. Both the drawer sides and bottoms will be plywood. So, I think that the drawers will be stronger if I glue the bottoms to the grooves and back.
Re: Glue in drawer bottoms??
Lee Schierer - McKean, PA
>I generally make my drawer bottoms out of 1/4" plywood and fit them in dados on all four sides. The drawer sides are usually 1/2" poplar. I do not intenionally glue the bottoms in place, though they may see some glue at the corners from gluing the dovetails. I make the fit between the plywood and dado snug. Ive never had a drawer bottom fail. If a drawer is going to see a lot of weight I would make the bottom from thicker plywood.
If you made your drawer sides from solid wood, all the sides are long grain so they aren't going to change length very much with seasonal changes. Nor will ordinary plywood. I wouldn't see a problem gluing a plywood drawer bottom into a drawer, made of solid wood, but it doesn't seem that it is really necessary.
Lee
AZ
>If you make the drawer bottom out of solid wood, you should anchor it (glue) at the front of the drawer, and if there is a screw at the back to provide a bit of stability, put it through an elongated hole. Then any movement of the drawer bottom will occur behind the the back of the drawer.
With a plywood drawer bottom, movement should not be an issue.
Jim Dillon
>Ralph,
I see no problem with glueing the plywood on all sides and I have done just that on a number of shop drawers, as well as on a nice end table for interior use (also with a plywood bottom). In fact, for a heavily loaded shop drawer, I would definitely glue the plywood bottom in place on all sides. For a solid wood drawer bottom, things are different as you are aware of. In that case, I place a bit of glue in the drawer front groove, and use a screw in a slot to hold the bottom to the rear. I've also used slips to hold the hardwood bottom in place, but the same cautionary principles hold for fastening the bottom. Just my 2 cents.
Jim
Jim Dillon
>Ralph,
Another reason I like to glue plywood bottoms all around is to prevent "vibration" of the bottom when one tosses a tool into the drawer (or closes a door with a loose fitting panel). Because of the poor qualilty of some plywood, I have had to cut the grooves for the bottom/panel wider than I would like so that I can easily slide the bottom/panel into place during glueup. Thus, glueing prevents the annoying (to me anyway) vibration noise. I haven't had much luck with the "space-ball" concept in preventing vibration as I usually forget to cut the groove deeper, and the elastomeric material kinda binds in the groove if the dimensions aren't quite right.
Jim
