We value your privacy.
>How do you finish the unseen or seldom seen parts of a table. I'm making a shaker style sofa table with two drawers in front. It's ash that will be stained dark then topped with an oil finish. I assume I stain the legs completely, even where hidden by the aprons. Should I stain the insides of the aprons? What about the drawer runners, guides, etc.?
>All depends what you want to see when you lay on the floor, or your critic friends drop over to check it out. It especially needs to be smooth all over, both for curious hands, and when you pick it up & move it.
I would at least stain the insides of the aprons, and drawer face edges. I leave the body of the drawer natural, but 100% varnish them to keep them clean, and don't show wear when scratched thru. I would also 100% varnish (with one coat)the underside to minimize moisture movement.
What ever you do, do a nice job of where the stain starts & stops. Stained or not, a ragged transition is a real eye catcher !
>What I would add to what Pete said , is rather then fight stain migration, stain it all except the drawer boxes which are a nice contrast left bare or maybe sealed with a clear coat.
I assume your drawer fronts are seperate from the drawer boxes.
Ash is my favorite wood to work with because it stains so nicely , stain it all ;-))
Keep finish off of the drawer runners and apply wax, I use paraffin in that location, but any is better then none.
>Don't put any oil base products on enclosed surfaces like drawer interiors. It will stink forever. It's okay to use shellac or lacquer here. A lot of commercial manufacturers do so. I usually leave the drawer interiors unfinished but if it is a real high-end type design I would apply finish.
As Fred mentioned, don't put any finish on parts that rub against one another.
Depending on how it is built I might finish the underside of the table top the same as the visible side to avoid cupping.
The rest of it - apron backs etc - is your option. I have a repeat customer that loves to see the nooks and crannies finished so that's what I do for her stuff.
>My rule is: what can be seen gets completely finished. What can be felt, gets a smooth finish. What can't be seen or felt, probably gets no finish. If finished at all, it's probably just a coat of shellac.
