REAL MILK PAINT
Pocket Screw and Glue
Stuart Johnson
>I'm building a sewing cutting table that is basically six file cabinet size cabinets. I'll be assembling them with pocket screws. How important is it to use both glue and pocket screws? I made several cabinets for the shop with just the screws and one with both screws and glue. I have not seen any difference but did find assembling using glue was messy.
Re: Pocket Screw and Glue
Dave Tenney
>Norm uses glue!
But as you say, I can't see how gluing long grain to end grain would hold very well. The last three cabinets I built I used glue on, but I'm not sure if it is really needed...especially after the face frames are glued and biscuited to the carcass.
I vote for glue
Dick Coers
Fred Davis
>Glue is better then no glue , much better then fastners alone, except where cross grain glueing is avoided.
FredD
Dave Tenney
>If I get a chance this weekend I'm going to put a couple joints together both ways and see if the glued joint is harder to break....
Dave
