We value your privacy.
My extractors sack is filling up again and instead of throwing it all out, I am wondering if I could mix it with some earth and put it on the compost heap. Most of the shavings are from a wood called Angelin Pietra, which is like bitacola and mahogony, although it also has some pine too.
>Most of mine goes in the compost pile with the trimmings from the garden, the clippings from the lawn, and the leaves that get raked up. Kept a bit damp, it makes a good addition to the clayish soils we have here. I need to add a nitrogen rich fertilizer to it, or it depletes the foods the plants need.
I'm not familiar with those woods, other than pine. What are they, and where are you?
Most of my sawdust comes from the turnings and hand work I do, although there is a bunch of stuff from my son's production of surfboards. Walnut, redwood, ash, maple, fir ply, various other types...
>IIRC from my organic gardening phase, sawdust composts quite nicely. The key is to provide a lot of nitrogenous waste to the mix. For the organic folks the additive of choice was chicken manure.
I am not familiar with some of the woods you named. Are any of them classified as toxic to any degree? If they are toxic then some consideration would be appropriate: what will the compost be used on? Will having it be potentially hostile to insects be good or bad? Even toxic woods will break down chemically in a while so toxic wood wouldn't be a deal breaker.
>Angelim is a common name given to about a dozen species of tropical American hardwoods. The closest reference I could find to your Angelim pietra is Angelim pedra (Ferreirea spectabilis or Hymenolobium spp.). From what I've read, most of the angelim species are extremely hard, heavy and decay resistant, which means they might not be good for compost as they won't break down easily.
As Glenn mentioned, sawdust robs the soil of nitrogen, so it needs to be broken down before you can use it as fertilizer. Manure, leaf mold, grass clippings and other yard waste are the recommended additives, usually in a ratio of about 3:1 to the sawdust. You need to keep your compost ingredients moist and well-mixed for the decomposition to take place. The pile should heat up noticeably as an indication that it is cooking properly. When it turns to rich black soil, it should be ready to use on your garden.
>I agree with John and Glenn. I "got into" composting for a while many years ago and composted all my yard waste and sawdust from my shop. At one point I was up to about 200%. Not only was I composting my waste, but I was taking in some form the neighbors too.
Sawdust is very deficient in nitrogen. The decay process that breaks down wood is about thirty times as aggressive at extracting nitrogen from the surroundings as a living plant is. So, it is very important that you provide a lot of it for the process. That can be fresh (uncomposted) chicken manure and/or grass clippings. It can also be nitrogen rich manufactured fertilizer. There are several chemicals used to provide nitrogen in fertilizers and I can not remember which is the easiest for the process to digest, but almost any of them will work.
You can go off the deep end playing with composting. Sort of mad science. Active or passive. You can trow the stuff out in a pile and leave it alone for several years or you can pile it in carefully constructed layers and wet it and turn it every few months or you can buy a composting drum where you load it in and turn it daily and have compost in less than a month. I was never willing to do all the turning and other work, some I made piles of mixed materials and left them sitting until I got around to using them.
Huge sawdust piles take many years to break down because they tend to shed water and have little or no nitrogen.
I had read that it generated a lot of heat. I looked out one fall day and one of my piles was steaming. I stuck a thermometer in it and it read over 140 degrees. Not believing it, I thrust my hand into the pile. And pulled it out very quickly. Yep! At least 140.
Now I just throw it on a pile in the edge of the woods. When I need some, I turn it over until I find the black stuff. I throw grass clippings on the pile when I have them. Still can't get into all that mixing.
>I don't know how much pine you have in your mix but do have a caveat.
some years ago I had several Ponderosa pines taken out and chipped. The chips seemed too useful to waste so I used them as mulch and dug some into the beds.
Looked good. Smelled good. BUT... nothing grew.
In one of those belated 'aha!' moments it dawned on me that pines are a source of turpentine. Not conducive to plant growth and likely inhibitory to bacteria in a composter.
>Nitrogen depletion is caused by the rapid increase in bacteria and fungus that will occur when something readily biodegradable is inoculated with these critters. They all require nitrogen to make more of themselves and they suck it up form their environment. Later when they run out of food they die and give it back in the form of decaying protein..
Green sawdust decomposes relatively quickly and in doing so it may cause a temporary nitrogen depletion. However, in my experience the dry stuff is so slow to decompose, even here in decay prone TN, that I don't observe a depletion of nitrogen when I mulch with it. I put a 2-3 inch layer on tomatoes and the like and by the end of the summer only a small amount of this stuff has composted.
>I compost all of my dust. However most (read nearly all) is very fine 150-220 grit thickness sander dust. When mixed with equal parts of "green" compost (living matter like grass clippings, fresh veggies, etc) it breaks down very quickly. With a 50/50 mix brown to green, I usually have complete compost in about 4 months. The winter is worthless here for composting so it all has to happen in the spring through fall.
Keep in mind that there are many woods that are very resinous to prevent infestation and decay. Those will eventually break down but it will take a long time. I use a lot of the various rosewoods and find that takes a lot longer to break down than spruce dust.
>First of all, many thanks for all your responses, as in everything, it seems one even has to "learn" how to make compost properly! I just thought I would like to please the wife and show a bit of interest in her gardening exploits.
The wood I mentioned, Angelim pedra, as Ellis correctly named it, is a mid to dark brown tropical hard wood. I came to like it as it's grain is quite wild and rustic looking. A friend of ours had his whole house fitted out with it and finished with a satin no colour varnish, the type that gets drawn into the wood leaving no film.
I have just finished reforming our bathroom, tiles and all that, and now want to add trim to the windows and edges of the butting out walls, so thought I would follow suite. I bought the wood, and am now in the process of planing it down to size. One problem I have come across, is that once planed, the wood exhibits various natural blotches or marks that are a bit unsightly. I am now working out who best I should distribute the various cuts to avoid them.
