Rikon 14" Deluxe Issues
Todd Stock
>I'm interested to see if other 10-325 owners have seen the same issue with the upper wheel hinge/tensioner assembly that I've seen and how they corrected the problem.
Specifically, the poor fit of the upper wheel shaft hinge (the T-shaped extrusion which holds the upper wheel shaft) in the sliding rail (the U-shaped extruded track within which the wheel shaft hinge runs) may allow the upper wheel rim to move out of plane (grab rim with hands...push one side in...pull one side out...note 3/16" movement), or radially.
My solution was to use two .013" UHMW-PE shims between the hinge and sliding rail after measuring the gap at .026" total. I've attached a quick sketch of the problem and shim locations, and would be interested in ideas on other ways to fix the issue (insert brass/UHMW screws as adjustable bearings, etc.).
Another issue that I am seeing is with a change from sealed bearings in earlier production runs (end of 2007) to shielded bearings in later production (by mid-2008), saws with shielded bearings on the lower guide assembly need frequent maintenance to clean sawdust out of the bearings. This is not a new problem for me, as my Delta 14" Carter guides all had the same issue (although Carter will tell swear that all their guides ship with sealed bearings...not). I'll be calling Rikon later today to see if this might be a warranty issue. Short of that, I'm going to check to see what might be available in terms of sealed bearings as a replacement for the lower guide assembly.
Finally - is anyone using compressed air to strip the blade gullets to enhance dust collection? I've seen this done on larger industrial saws, but was curious as to whether anyone has tried it on the Rikon or other small saws.
