What are Draw Pins?
What are Draw Pins?
What are Draw Pins?
Dave Tenney
>I've seen these things mentioned in a couple of threads...What are they?
Dave
Re: What are Draw Pins?
>Not sure, but I thought draw pins were used to draw a tenon into a mortise. You drill though the mortise, then insert the tenon and mark it. Remove the tenon and drill the hole through it offset a few hundredths of an inch. Then when the joint is assembled and you drive the pin through it, the pin tends to pull the tenon in as deep as possible. Not only used on furniture but also on timber framing of buildings. Might post this on the hand tool forum and see if they know more on the quiet side.
>Norm uses them to keep his pants up if his belt breaks.
done on the art class field trip to bowling alley
Read about them here *LINK*
Charles R. Smith
>You can read about them here. They are of value both in woodworking and in machine work, where they are called drift pins and are used to bring bolt holes into alignment when assembling machinery.
You can make your own, as Chris suggests, or purchase really nice ones from LN or (coming soon) LV.
Charles (who has decided to buy rather than build his own)
Drawboring Resurrected by Christopher Schwarz
Re: Read about them here
Dave Tenney
>Thanks!
I saw these in a book, as well as a post below and was curious what you would use them for.
I've never made mortise and tenons with offset holes, but may have to give this a try.
Dave
Now that's funny!
Dave Tenney
paul waddle
>a more descriptive term would be alignment or tapered pins. I think most of us would know them by this term.
some people draw mortise and tenon joints together by drilling the tenon hole about 1/16th on the center line but back toward the cheek to pull the tenon tight,the pins or pegs are slighly tapered to get started,but otherwise straight-these are true draw pins. pw
