saw Blades
saw Blades
saw Blades
gfriend
>Whats the best saw blade for a compound miter saw? Looking for one that doesn't give tear out on the end being cut.
Re: saw Blades
Depends on
Dustmaker Mike
>what you are cutting. There are a few tricks to stop the tear out can you tell us more about what you are doing so we can answer better.
Re: saw Blades
I agree......
>I have a Forrest Blade on my TS. I like it. They make a blade for a chop saw. One of the key features is it has a negative rake angle on the teeth. I want one. I'd bet my money on it. If I had any money for a saw blade.
Re: saw Blades
Re: I agree......
Fred Davis
>did you mean negative hook angle?
FredD
Re: saw Blades
Close enough!, Sorry about that
Re: saw Blades
Re: saw Blades
Jim Dillon
>Don't know about "best", but as Barry, I like my Forrest blade designed for miter saws. Not inexpensive, but sure makes a smooth cut. But I am sure there are many other nice blades out there as long as one compares apples-to-apples pricewise. However, if I were just using it for carpentry stuff, like cross cutting 2x4s, 2x6s etc., I would look for a less expensive blade and save the more expensive one for another day.
Jim
Re: saw Blades
A sharp one!
John in NM
>However, premium blades like Forrest and Ridge will tend to be balanced better. Also helps to have a negative hook angle for the teeth as the cut is less aggressive. I've been running $40 Freuds for years and never had a complaint - but then I'm easy to please.
