Bark on Mantle
Bark on Mantle
Bark on Mantle
Brian in Cheyenne
>I am planning on building a mantle above our gas insert fireplace, and need some advice.
My brother in VT has graciously offerred up some hard rock maple to use as a mantle...I'd like to keep the bark on part of it...is this possible? Or will it simply fall away over time? One of the big issues will be moving it from VT, where it's hot and humid, to WY, where there is no humidity.
Opinions?
Re: Bark on Mantle
I have seen it done
Dustmaker Mike
>but the success rate is about 50% that the bark stays on for an extended period of time. I made some benches a few years ago of of Doug Fir with the bark on. Parts of it still has the bark on but for the most part it has all fallen off.
Re: Bark on Mantle
Did you coat...
Brian in Cheyenne
>the entire piece in polyurethane, including the bark? If so, did it change the color of the bark substantially?
Re: Bark on Mantle
Re: Bark on Mantle
steve mackay
>I know if I could shell out for the shipping I'd take it ! Even if all I wound up with was something to mill out smaller. But then, you never know. Might turn out OK for the mantle.
Re: Bark on Mantle
Nope I did not
Dustmaker Mike
>use Poly. I used out door deck finish. This bench sits out on my front porch for the spring summer and fall then gets moved into the garage.
I have two other pieces from the same slabs that have not been finished at all and the bark is ready to come off of them as well. These two pieces have been stored with my wood stack inside and dry.
Now to get it moved to you from VT if I can get it here in OH before May I am driving out west and may be able to get it to you depending on the size. I will be heading to SD to see the Big Heads on the mountains. I guess I could take 94 instead of 90 just not sure how much time that will add to my drive.
Re: Bark on Mantle
Re: Bark on Mantle
Fred Davis
>"it's hot in Vermont"
when , what year ?? LOL ;-))
reminds me of a timeless tune,
What pop standard of yesteryear has lyrics that do not rhyme ?
FredD
Re: Bark on Mantle
Re: Bark on Mantle
Dick Coers
>It is almost too late for this year. The most successful work, with bark staying on, is from wood that is cut when the sap is down. Very late fall and winter are the very best times. The cambium layer is hardened and shrinkage will not be a factor in loosing the bark. If you cut wood in the spring, the cambium is almost as soft as a sponge. The shrinkage will be great. (Ask George Costanza) Now there is another consideration. It is illegal to ship some wood, with the bark on, in many states. You may just be shipping bugs from Vermont with the wood.
Re: Bark on Mantle
Thanks, Mike!
Brian in Cheyenne
>Thanks for the offer to bring it from OH, Mike! I'm thinking I will just take a vacation and go see some family...picking up the wood along the way of course!!
The Big Heads are about 4 hours north of here...you'll love it!! The Black Hills are one of the prettiest places around these here parts!!
Re: Bark on Mantle
Re: Bark on Mantle
Jim Dillon
>Brian,
Probably hard to really predict as so much likely depends on the original drying process and how tight the bark is to the tree after drying. My only experience is with a two inch thick oak diner table with the bark left on approximately 12 linear feet. Multiple coats of Watco Danish oil were applied 30 years ago and some since then and everything is fine. But, as they say, YMMV. I think natural-edge wood turners deal with this problem all the time and a post to the WC wood turners forum might yield results. Granted, turners are likely dealing with thinner stock than what you had in mind, but you might get a different perspective.
Jim
Jim
Re: Bark on Mantle
Re: Bark on Mantle
BrianA
>I made this bed about 5 years ago and coated it with "Liquid Wood" epoxy wood consolidant by Abatron. Have not had a single piece of bark fall off. Worked great and will use it again when I make the manlte for our fireplace.
Brian
