Weekend(s) accomplishment
Dave Paine
>This is a project which was inspired by a 3in by 3in clip board for a grocery list which was built from strips of different species of wood cut at an angle and the strips "flipped" from end to end.
I thought this would work well for a trivet (hot pot support).
I wanted this to showcase the natural colours in different wood species. This is the natural wood, with one coat of oil. No staining.
The design opens up. The other pictures are on my wife's PC. This is the "closed" picture. If there is any interest I will post the "open" picture.
The solid border is comprised of a wood labelled as "Dalmation" (Swartzia Arborescens) strips top and bottom and in between 1/8in strips of hickory-wenge-hickory.
This will be a gift to my friends wife who provided the inspiration.
The strips were glued together in a 40in long slab. I have enough to make 3 others. Showed this to my friends at work, and should not have any problem finding homes for the others.
As for the number of weekends. This was started in early December. The design evolved over time. For example the strips "moved" and split when first used. I needed to reinforce. I decided to glue Wenge 1/8in strips to the sides. Solved the structural issue, and in my opinion, improved the design.
