OT: installing programmable thermo
Mike Schwing from Maryland
>Hi All!
Hope you don't mind the OT post but I didn't know where else to go for this and be assured of an answer.
I'm trying to install a programmable thermostat in the house where I am presently living and have an issue. I have attached relevant pictures and hope they help.
There are 2 wires on my existing installation that seem to have nowhere to go on the new thermo, the black and brown wires, labeled X and E respectively in the image below of the existing wiring.
It is a single unit, so I have chosen this wiring diagram for the source as I think it fits best, although there are more than 5 wires. I assume "single transformer" means a single heat pump unit, as opposed to my other house that has two?
I've done more difficult things than this for sure, but don't want to do the wrong thing. Anything else I'm missing? Do I have it all wrong? Do I not need these 2 wires for the new thermo? Is there more info I can provide? Should I not attempt this? Thanks!
Old thermostat
New thermostat..
Re: OT: installing programmable thermo
Lee Schierer - McKean, PA
>I would check the heat pump connections and see which wires are actually connected to which terminals in the heat pump.
Lee
just did that
>Great idea Lee. I also found the heat pump wiring diagram while examining the wiring. I found this - the brown and black wires I was concerned with aren't used anywhere that I can see. The brown looks to be a wire for the external thermostat, which is not installed in this unit. The black - I don't know but it doesn't appear in this diagram, so I'm going to wrap it.
Further thoughts?
Not an expert
>Your furnace diagram is a bit hard to make out, but it appears that the terminals are labels from left to right as: R O C W G R B. I looked up your thermostat on the internet and they provide another diagram for connection that will help if you can identify which terminal operate which functions of your system. See attached photo.
Assuming your current system is working. What terminals in the heating unit are currently have wires connected to them that go toward the thermostat? Depending upon your unit you may have a remote mounted 24 volt transformer too.
Lee
Re: Not an expert
>It seems to be working! Will keep an eye on it. Thanks for your help!
